The 4th Gen Dash Swap Guide.
Old Sep 12, 2010 | 10:13 PM
  #51
Faded's Avatar
Car: '91 Firebird
Re: The 4th Gen Dash Swap Guide.
I'm not sure if I ever posted these, but here's some pics of how I modified the 4th gen ducting to fit my 91 Firebird.
Attached Thumbnails The 4th Gen Dash Swap Guide.-airbox1.jpg   The 4th Gen Dash Swap Guide.-airbox2.jpg   The 4th Gen Dash Swap Guide.-airbox3.jpg
Old Nov 7, 2010 | 06:31 PM
  #52
92redhotcamaro's Avatar
So I'm figuring i will do this swap this winter while my car is off the road. I have a 92 camaro. If i leave my gauges what dash would be best to use or are they all the same? And if i decide to swap my guages what goes with what and will work i got confused with the way you layed it out. (Camaro dash 93-96 works with ......gauges) and (camaro dash 97-02 works with .......guages) and (Firebird dash 93-02 works with......gauges). Sorry for the question being so long but i didn't know how to make it shorter .
Old Nov 8, 2010 | 04:25 PM
  #53
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
so...any of the fourth gen dashes work with the third gens with some wiring mods?
Old Nov 8, 2010 | 04:48 PM
  #54
as far as im understanding yes......so i decided on getting either the 93firebird dash or the later years 2002 dash. What gauges do i need that will work in my 92 camaro with the firebird dash (I want gauges that bolt right in). And again if i do not change my guages will everything still work and look good or will there be gaps?
Old Nov 8, 2010 | 05:44 PM
  #55
dans89's Avatar
Car: 85 z28
STICKY THIS THREAD PLEASE!!!! and thanks for all the awesome info
Old Nov 9, 2010 | 11:40 PM
  #56
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Originally Posted by 1ADan
i feel like a dummy right now, but I'm in the middle of my dash swap and for some reason, cant figure out the dimmer switch wiring for the life of me. The connectors between my 87 ta dash and 98 ta are the same and I know the black (ground) & white (dome) wires are direct swap. but the two outer wires I can't figure out. what are the A and D pins for on the vehicle? I've got the schematic for the new dash.
i'm pretty sure those are for the dome light. Ground 1 of them and run the other to the ground side of the lights. It doesnt matter what order you put those 2 wires in. I guess this guide still needs some work clearing things up lol
Old Dec 4, 2010 | 12:23 PM
  #57
Neuntoter's Avatar
Someone else asked this too but what if you are using a carburetor engine is everything still going to work? What I am thinking is a 02 Firebird dash in a 82 Firebird.
Old Dec 4, 2010 | 05:15 PM
  #58
ShMaCk2004's Avatar
you will need a 93-97 cluster
Old May 3, 2011 | 04:30 AM
  #59
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
i have a 97 lt1 v8 gauge cluster i want to put in an 85 firebird with cable driven speedo and t700r4 auto. the speedo has the yellow box on the back that takes the cable reading and converts it to a signal for the ecu.
questions:
what signal does the 165 ecm receive from the optical pickup?
what ppm signal does the lt1 gauge need?
what ppm signal does the vss send?
Do i need a speed buffer box, or can i keep the cable speedo and run the lt1 speedo off the ppm wire from that?
Old May 5, 2011 | 05:30 AM
  #60
evilstuie's Avatar
anyone?
Old May 28, 2011 | 01:39 AM
  #61
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
I'm assuming you've figured this out by now but if not, heres the breakdown for the stock third gen dimmer switch wires (incase anyone else needs help)....
You are correct with the black as ground and white for the dome light power. The other two outer wires which are brown, and green with a white stripe go as follows.. Brown gets T'ed into the parking light circuit off the headlight switch. This supplies the dimmer switch with power when the lights are activated. The green with white stripe wire runs to a remote dimmer box right under the dash to the right of the steering wheel (looks like a small heat sink). This gives you more of a smooth range of dimming. There are 2 more wires coming off of the remote dimmer. One is solid green which is the output wire that dims anything you hook it too, and the other wire (brown) will also get plumbed into the brown parking light power wire off the headlight switch.
Old Jun 7, 2011 | 06:06 PM
  #62
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
For the ones who done the 98-02 dash swap... Did you use the 98-02 a pillars also?
Old Jun 12, 2011 | 11:25 AM
  #63
DRD92RS's Avatar
Car: 89 IROC Z, 95 Formula
I have seen one car that had the a pillar trim cut to fit and I am attempting this myself as well. Others have fiberglassed the bottom portion onto the factory a pillar trim and I have also seen one with custom caps made for the gap.
Old Jul 6, 2011 | 07:45 PM
  #64
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
subscribed, and STICKY!!!
Old Jul 30, 2011 | 07:38 PM
  #65
cw3adkins's Avatar
Car: 87 IROC Z-28
Engine: 5.0L 305 TPI V8
Okay, possibly dumb question but after searching and everything, I figured I'd ask. Does anyone know the signal input on a 93-96 cluster for the speedometer? Is it just the GM 8K pulse or is it something else?
Old Jul 31, 2011 | 07:23 PM
  #66
evilstuie's Avatar
I too would like some info on this.
I've got a t700r4 with cable speedo going into an 85 gauge cluster that has the optical pickup that sends the signal to the ecm. I need to know if I can use the optical pickup on the back, and wire the 95-96 lt1 speedo input directly onto there and run the unit off that, or if I HAVE TO use a VSS?
Old Aug 1, 2011 | 06:32 PM
  #67
Sparkko's Avatar
Car: 1988 Firebird Formula
Engine: 5.0L 305 TBI
This deserves to be a STICKY!
Old Sep 1, 2011 | 04:50 PM
  #68
jamieschott's Avatar
Has anyone came up with a good solution for the temp cable? I ve read that someone thought the 94-95 Camaro cable was a few inches longer than the Firebird cable or even the 97-02 Camaro cable.
Any solution to its mounting to the Heater door arm?
Old Sep 4, 2011 | 05:58 AM
  #69
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
So do you need the entire 4thgen dash harness?
Old Sep 6, 2011 | 02:29 PM
  #70
evilstuie's Avatar
ANYONE?
Old Oct 2, 2011 | 01:52 PM
  #71
cookie21's Avatar
Car: 1992 RS
Engine: ZZ4
Ive got a 92RS with a T5, ZZ4, and i have a dash with cluster from a 2000 SS, can i use this cluster or do i need a firebird one, and i think since it was a v8 car to start i DONT need the dakota digital box, correct??
Old Oct 3, 2011 | 11:18 AM
  #72
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
you need the Camaro 97 cluster. or the Firebird 94-97 cluster..
Old Oct 3, 2011 | 02:18 PM
  #73
cookie21's Avatar
Car: 1992 RS
Engine: ZZ4
along with the firebird 94-97 harness? sorry just trying to make sure the SS one wont work before i get rid of it.
Old Oct 4, 2011 | 11:49 AM
  #74
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
no you can actually use a harness from the LS1(98-02) firebird/camaro... the cluster connector is the same, i know because im using one. so is the headlights and radio and all other connectors.
the only variable in the swap is the cluster... the 98-02 clusters wont work without the 98-02 PCM since it gets the signals from it.. with an LS1 PCM to work, you either need the LSx engine or the EFIconnections.com 24x conversion.
Old Oct 4, 2011 | 02:10 PM
  #75
cookie21's Avatar
Car: 1992 RS
Engine: ZZ4
Thanks! I just wanted to make sure i had the right parts for my "specific" swap...
Old Oct 7, 2011 | 09:21 PM
  #76
cookie21's Avatar
Car: 1992 RS
Engine: ZZ4
Can anyone tell me how far back to cut the wiring harness for the dash? Im going to get the one out of the car my dash came from tomorrow and i need to know how far back to cut it....Thanks!
Old Dec 28, 2011 | 07:53 PM
  #77
schmbrt96's Avatar
I have a 92 camaro rs 305 tbi with a 700r4, I want to do the dash and center console swap. What cluster do I need, what dash, and what center console. I'm sorry if this has been answered, but all these different pieces are confusing me. So I just am asking what pieces do I need.
Old Mar 3, 2012 | 07:30 PM
  #78
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Starting my dash swap soon, using this as a reference!!! thanks for all the INFO!
Old Mar 4, 2012 | 01:34 PM
  #79
92RSsleeper's Avatar
Car: 92 Camaro
Engine: 404 SBC
Transmission: The strongest stock T5 ever made
Axle/Gears: 3.73 w/Detriot Tru Trac Locker
I really can't stand people that post useless comments just to say something, but I NEED to chime in with a big STICKY
Old Apr 6, 2012 | 11:59 PM
  #80
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Sticky sticky sticky!!!
Old Apr 12, 2012 | 07:39 AM
  #81
krzyz's Avatar
Car: 1982 z28
Engine: 383
Transmission: 4l60e
Axle/Gears: 3.73 posi
ok im not sure if I missed it any where but Im picking up a bunch of 4th gen firebird dash parts to finish my swap and Im getting a cluster from a 93-97 firebird v6 car for free, Now will my lsx ecm be able to run the cluster or will I have to hard wire the cluster into my engine senors?
Old Apr 27, 2012 | 09:50 AM
  #82
firebirdfreak87's Avatar
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
im lost on the wiring any easier way to figure it out
Old Apr 28, 2012 | 03:09 PM
  #83
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
no you need the LS 98-02 cluster so its a plug and play..
Old May 9, 2012 | 11:52 PM
  #84
JacobIroc's Avatar
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
Does anyone know if there is a way to run a 98 - 02 Firebird/Trans Am cluster on a stock third gen?... The 93 - 97 is ugly IMO.
Old Jun 8, 2012 | 04:48 PM
  #85
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
so i'm converting to ls1/t56 soon. so i'll need to run the 98-02 cluster? i keep hearing that i need to run the 93-97 cluster because of a 90ohm fuel sender something... which cluster do i need to run?!
Old Jun 11, 2012 | 07:56 AM
  #86
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the earlier clusters use analog sensor input like the factory 3rd gen setup, the later ones use the pcm serial bus instead. if running an LS1, you can choose either option.
Old Dec 5, 2013 | 10:45 AM
  #87
swittke1217's Avatar
ok I see what you got going with your car I have a question for you I have a 96 z28 with a lt1 in it and 4l60 trans and I have a 92 Camaro rs 25th anv what I am wanting to do is take two cars make one they both run really good and both pretty fast but I wanna make my lt1 and trans to my 92 Camaro and I would like to take my 96 Camaro dash out and put it in my 92 to I know you said you had to do some trimming on things to get stuff to work but I was wondering if I could just take everything out dash hvac hoses heater and all from the 96 and put it in the 92 would that work with out trimming anything up
Originally Posted by ShMaCk2004
Silly TGO limiting me on pics per post...
Pic post 1
Old Jun 16, 2014 | 11:22 AM
  #88
motocrosser984's Avatar
ok im aj and in the middle of a ls1 swap in my 93 camaro and wanted to know since i really like the 98 transam cluster....also its my donor car everything coming from it... it was a running and driving ls1...can i use the trans am cluster and dash in the camaro... i have all the wiring in the car so i can strip it bone dry....is it possible i should say.
Old Jul 7, 2014 | 04:57 PM
  #89
ShMaCk2004's Avatar
Been away for a while, going to be updating this with adding a 4thgen hvac box to it.
See thread here https://www.thirdgen.org/forums/inte...c-my-87-a.html
Old Jul 13, 2014 | 02:00 AM
  #90
Hoonigan's Avatar
Car: 1986 Iroc Z28
Transmission: 5 speed
Axle/Gears: Stock
Might pick up a non running 4th gen 1995 V6 just for the dash and console, looks auto but can manage some sort of 5 speed hole. Would I be able to put its dash and console into my 86 z28? With using youre info
Old Jul 13, 2014 | 10:48 AM
  #91
ShMaCk2004's Avatar
It should work as any other 4th gen dash/console
Old Jul 13, 2014 | 09:22 PM
  #92
Hoonigan's Avatar
Car: 1986 Iroc Z28
Axle/Gears: Stock
Yea I figured it should, I really like the dash in the 3rd gens better, but I want a different gauge cluster.
Anyone wanna show their custom 3rd gen dash gauge clusters?
Old Jul 14, 2014 | 09:46 AM
  #93
ShMaCk2004's Avatar
Theres been people on this site doing LS1 clusters in 3rd gen dashes for a while, just search it. I know you will have to mod the 3rd gen dash to fit it like cutting plastic and that sort of thing but its been done plenty of times.
This should point you in the right direction.
https://www.thirdgen.org/forums/inte...auges-3rd.html
Old Aug 27, 2014 | 04:42 PM
  #94
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
If u guys have any wiring questions for thirdgen dashes..I made a video on just that..
Old Aug 27, 2014 | 05:11 PM
  #95
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
http://youtu.be/KKwgL3pI05g
Some things.
  • When it comes to the GM speedo's its Pulses Per Mile. It can't be Pulses Per Minute because the output varies with speed.
  • You don't need to drill a hole in the chassis if the car started life as an automatic transmission (maybe even as a T5). There is already a Gromet forward of the ash-tray area under the radio pod.
  • Your location for the VSS wires might become problematic if the Trans mount breaks because the trans can crush the wires.
Other than that, good video. Doesn't apply to all swaps, but contains some good information.
1993 T56's are 11 pulses per revolution of the output shaft. 94 and up are 17 PPR.
Old Sep 18, 2014 | 03:42 PM
  #96
keithk1973's Avatar
Car: 92 RS
Engine: 5.0L
Transmission: 5 spd
What dash pad do you use?
Old Sep 23, 2014 | 03:16 PM
  #97
Broggo's Avatar
Car: 1984 Camaro Berlinetta
Engine: 2.8l v6
Idk if this will matter much at all, but i have the 84 berlinetta with the 2.8 v6, I'm swapping that with the 3.8 out of a 2001 firebird, both automatics, (please do not tell me to do the v8 swap instead, I have my reasons for the v6), at the same time, I'm wanting to install the dash out of the firebird as well... ...approx how much of this will apply to me and if any advice is available, I'd appreciate that as well.
Old Mar 10, 2015 | 09:36 PM
  #98
ricom's Avatar
I am reading and I do understand that there are differences bet 93-96 Firebird/Trans Am and 97+ Dash. I got a 95 dash that the vinyl is damaged by the sun, and I cannot find a good one to replace it with. There are some from 97+ Firebirds available. Can they be swapped?? What is the differences between the two except the digital mileage reader and I think air bag is also different? And if I am to buy a new dash from the scrap yard, do I need to pick up something else to make it work? Any help would be appreciated...
Old Aug 20, 2016 | 01:27 PM
  #99
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Anyone know if the gauge cluster has to be reflashed to the PCM? I'm having issue getting serial data to the gauges, so my RPM gauge doesn't work along with the rest associated with the serial data.
I tapped directly into the wire from the PCM and it's not working. The check engine light and other lights are working.
Old Aug 22, 2016 | 12:59 PM
  #100
Dodgeman79's Avatar
Car: 86 Z28 Camaro
Engine: 5.7 Vortec
I got my dash and I'm about to start this. But how do you remove the passenger air bag?
