is there specific way to mount aluminum spare tire
Old Apr 9, 2010 | 06:58 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Is there a specific way to mount the jack stand with an aluminum spare tire in the wheel well compared to the regular blakc donut?
and different hardware pieces?
Old Apr 9, 2010 | 07:00 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: is there specific way to mount aluminum spare tire
you put your tire in first and then the jack goes in on the side of tire closest to the front of the car...
Old Apr 9, 2010 | 07:03 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok ill try that thank you, i think my car originally came with a blakc donut but not sure.
the jack stand was bolted going arcoss the quarterpanel behind where the wheel would be.
but the aluminum tire is giving me issues so ill try to mount like u said
Old Apr 9, 2010 | 07:05 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mine has the jack mounted first and the tire goes on afterwards.
KNBlazer's Avatar
Engine: 5.1 4bbl
so then the tire does not want to go in? did you have to put air in it when you used it... did one side bulge out and then evened out?
Old Apr 9, 2010 | 07:07 PM
Bobby_80s's Avatar
Axle/Gears: no idea
basically i can get the jack stand in going across. then i just about wedge the wheel in there. but my problem is getting the hook bolt inside to hook into that loop bolt.
its just no room to work with the jack in the way
without the jack i can hookup the tire no problem
Old Apr 9, 2010 | 07:09 PM
Zepher's Avatar
jack should sit almost vertically.
look at the pic above.
the jack has it's own rod to hold it to the car and the spare has it's own rod, at least on my car.
Old Apr 9, 2010 | 07:17 PM
Bobby_80s's Avatar
Axle/Gears: no idea
i know but in my 86 trans am theres a bolt that holds the tail end of the jack stand going diagonally towards the speaker and then behind the center of the wheel there a bolt hole taht perfectly lines up on the other end of the jack stand.
i think with the more common black donut spare thats how it goes in.
but i have an aluminum one now that did not originally come with the car and i dont have any bolts to hold the jack stand vertically.
ill figure it out guys. im at work i'll try again thing weekend with these new ideas and ill let u know how it goes
thanks
Old Apr 9, 2010 | 07:18 PM
Zepher's Avatar
I don't have a spare in my car and I'll try and remember to snap a pic tomorrow of how the jack is mounted since it is still in there.
Old Apr 9, 2010 | 07:21 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok cool thanks.
when i bought my car all it came with was the jack stand and it was mounted diagonaly or more horizontal.
i had to buy the spare tire and hardware stuff seperately on ebay. so im just trying to figure it out. didnt think it be this hard.
and if i didnt need the jack stand id be good haaha. but ill try different combonations when i can.
Old Apr 14, 2010 | 05:55 PM
Bobby_80s's Avatar
Axle/Gears: no idea
its all set guys thanks. i went looking through a box of spare nuts bolts and screws and found a loop bolt thats much longer. it bolts the jack stand in the center and then i can put the tire in. and then put the hook bolt in and hook onto the loop bolt.
then tighten it down with that circle dish to hold the tire and the silver handle that spins down to hold it alll together.
everything is fine now thanks guys for all your input
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
69 Six Pack
Oct 5, 2015 07:51 PM
