Thinking about covering my dash with fiberglass
Old Apr 11, 2010 | 12:53 AM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
After repairing my headliner with fiberglass and doing a little body work to my camaro I want to try and cover the old cracked dash pad in fiberglass and paint it to match the interior has anyone done this? If so does anyone have any pics?
Old Apr 25, 2010 | 11:03 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: Thinking about covering my dash with fiberglass
No pics, but its easier than a headliner. Just reinforce everything with fiberglass resin/mat, then use some sort of finishing (icing) body filler and sand till level. Primer, then match color. Stronger than new.
Old Apr 25, 2010 | 11:12 PM
shiftngo's Avatar
Car: 1987 IROC
I was thinking of doing the same thing. I think it would look awesome. Post pics when your done. Prefferably with a little how to.
Old Apr 25, 2010 | 11:32 PM
Car: 1992 RS 6spd
1. remove dashpad. 2. clean off and cut away at curled cracks, and remove loose foam. 3. either fill valleys in dash with some sort of fiberglass fiber resin (recommended) or bodyfiller, (bondo, cheaper and not really recommended.) 4. When the filled cracks harden, lightly skimcoat the top and anything else not level with a good "icing" finish coat. 5. use a guidecoat of cheap flat primer to sand top level. 6. clean with grease and wax remover. 7. Primer with sandable primer, guidecoat primer and sand flat. 8. Paint dashpad color of choice, let dry.
Old Apr 26, 2010 | 12:09 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
i want to do this to. paint it blue to match my car.
Old Apr 26, 2010 | 05:00 PM
shiftngo's Avatar
Car: 1987 IROC
Preciate it calamitas
Old Apr 27, 2010 | 10:04 AM
Car: 1988 camaro
Engine: cammed 3.1
I've been a bit busy this past week so I haven't been able to work on my car I'm not sure when I'll be able to but ill post pics of the progress on how it turns out when I start on it. Does anyone know if fiberglass or bondo will stick to the vinyl pad?
Old May 6, 2010 | 02:55 AM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
Yes to both of your questions. I recommend against using bondo as it will simply recrack... It does not work good for filling in cracks. I'd recommend using fiberglass.
Old May 10, 2010 | 01:49 AM
Car: 1992 RS 6spd
Like I said lol, use fiberglass to fill all of your imperfections, then skimcoat with bondo, sand it down till even, primer then paint desired color or use some sort ov vinyl covering.
Old May 10, 2010 | 01:50 AM
Car: 1992 RS 6spd
Just trying to pass on the do-it-right the first time knowledge bro, money is scarce these days lol.
Old May 10, 2010 | 04:40 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
I used some urethane epoxy that is still flexible when dry. Check out post #18 below. Not sure bondo is such good idea since it can absorb moisture. Regardless I found that underbody texture or bedliner spray works good to give you similar texture to stock. Just be sure that you spray texture a few seconds in the air before coating dash. That way you can get even texture coating.
https://www.thirdgen.org/forums/auto...-dash-pad.html
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Jan 29, 2017 07:00 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Vintageracer
Aug 11, 2015 08:13 PM
