tach going crazy
Old Apr 16, 2010 | 09:09 AM
elucente330's Avatar
tach going crazy
i have an 86 iroc and the tach is being really wierd it doesnt work at all wen started but wen the ignition is turned to the on position the needle moves higher and higher as more power is drawn from the battery... please help me!!!!!!!!!!!!!
Old Apr 21, 2010 | 12:22 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: tach going crazy
try unplugging your tach, your tach is controlled by the ignition coil. maybe its the coil, couldnt hurt to test it
Old Apr 22, 2010 | 08:20 PM
thanks ill try that tomoro
$750 L98
Feb 1, 2025 02:25 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Zell1luk
Sep 29, 2015 10:36 AM
Eric-86sc
Sep 28, 2015 11:37 AM
