4th gen dash with exploded Airbag????
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I have an opportunity to get a 4th gen dash COMPLETE for $100. Only thing about it is the airbag on the dash has been opened. Does anyone know if the spot for the airbag to come through on the dash is replaceable?
...or, has anyone used a dash that has had the airbag already blown? I'm open for ideas.
Thanks!
Thanks!
Car: 89 Camaro RS
Engine: LM7
Re: 4th gen dash with exploded Airbag????
I'm in the same boat. I found a company that makes an cover for $75.00. I'll post the link when i get home. It may end up cheaper/eaiser to find a dash without a blown airbag. I was able to use my blown cover as it was still in good shape.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
looks to me like the bag just pops open the door on the dash to deploy. if thats the case it shouldnt be hard to replace. i know on some newer dash bags, they actually blow part of the dash apart to deploy. but im no expert on the 4th gen dash.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Not sure if it's legal to ship them, but I see undeployed airbags on ebay all the time for sale, and I've even bought one there before - might be able to just replace it yourself for same as that $75 coverplate mentioned above.
Car: 89 Camaro RS
Engine: LM7
The cover is part of the dash and has nothing to do with the airbag. When the airbag goes off it tears the dash material around the cover. only way to fix it and make it look new is to buy a new dash. Here's a link to the only aftermarket cover i could find.
http://store.hicksairbagcovers.com/c...at=11&scat=154
Car: 87 iroc z28
Engine: 89 C4 TPI ,
Transmission: ZF6 speed , 89 C4
Axle/Gears: 89 corvette rear end
My 4th gen dash had a blown air bag see 1 RAPID 1 ,cut away all the bag and metal.Then trim the lid and glue it on,or find a new (blown) one at the wrecking yard !
Car: 87 GTA
Cut it all out & use it as a (doorless) glove box. Or fab up a door for it.
Car: 91 Camaro RS
Axle/Gears: 3.23:1
Well, I wasted 60 minutes of driving only to find out that the dash was not only missing half of everything, but also cracked. What a waste of time.
ambainb
Apr 25, 2016 09:21 PM
