Locking panel in trunk, with wire leads o.O??
Old May 14, 2010 | 12:20 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
What is this thing for, it has a bunch of wire leads in it, also its lockable??
And another question, I heard the t-tops when removed can be locked down in the hatch somehow so they dont roll around back there, I can not for the life of me see any way to do such a thing...
Attached Thumbnails Locking panel in trunk, with wire leads o.O??-100_0354.jpg
Old May 14, 2010 | 12:48 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Locking panel in trunk, with wire leads o.O??
There is supposed to be a cardboard "box" like structure behind the compartment, its just storage. The wires are for your taillights, they arent supposed to be visible. The T-tops go in a bag, which straps down to the 4 metal mounting points.
Old May 14, 2010 | 12:59 AM
Engine: 3.8, 3.4
No, they're deffinitely not tail light wires, because 1, I can visibly see the tail light wires if I look for them, my tail lights work, and these aren't not wires that run through the box, they're leads that go into it, there is nothing connected to them on this end...I'm suspecting they might have been for subs, but the car doesn't have any, it's the only thing I can think of though...
As for T-tops looks like I need to get a bag then..
Old May 14, 2010 | 02:40 PM
Than I need a pic. The only wires that run there from the factory are the taillight wires, and on the earlier models, a wire that ran to the fuel tank. They are most likely wires from an old sound system, though.
Old May 14, 2010 | 03:07 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
speaker wires? idk..mine are ran thru that box..
Old May 18, 2010 | 01:54 AM
JackRs's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
Lol so its just a weird stash box?
Old May 18, 2010 | 02:03 AM
Engine: 3.8, 3.4
Not sure...I'll take a picture next time I remember to...
Old May 29, 2010 | 09:14 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
prob sub wires. here are the wires leading to trunk in an 85 TA.
the t-top locking you are thinking of is only in 4th gen f-bodys as their t-tops are smaller to fit in the well in back.
im actually going to make a custom box the tops will lock into as i find the t-top bag set up kinda cheesy and i almost always run w/ tops off.
Attached Thumbnails Locking panel in trunk, with wire leads o.O??-runnersegr-012.jpg   Locking panel in trunk, with wire leads o.O??-runnersegr-024.jpg
Old May 30, 2010 | 01:44 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
http://cgi.ebay.com/ebaymotors/82-92...Q5fAccessories
Here is a t-top bag for sale on ebay--$44 shipped. The straps attach to the hooks you have in your trunk--keeps the t-tops locked in place.
Old Jun 1, 2010 | 06:55 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You're also going to need to find the hooks for the t-top bag. If there aren't any behind the tail panel as well (what the 2 slits that are on either side are for), you'll need to pick up all four of them. There will be 2 pairs, a tall set and a short set, the short set screwing to the gas tank hump. You'll see a pair of holes on each side of the hump about 2/3 of the way towards the seat from the rear well. That's where the hooks go.
Old Jun 28, 2010 | 08:17 PM
Engine: 3.8, 3.4
Here's the pics of what I'm talking about.
Attached Thumbnails Locking panel in trunk, with wire leads o.O??-100_0458.jpg   Locking panel in trunk, with wire leads o.O??-100_0457.jpg   Locking panel in trunk, with wire leads o.O??-100_0456.jpg
Old Jun 28, 2010 | 08:27 PM
stealtht/a's Avatar
sub or amp wires. definetly not factory.
Old Jun 28, 2010 | 08:32 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I would guess on a CD changer. The larger ones are data wires used to communicate between an HU, CDC, and either a Sirius, XM, or iPod adaptor box. If you pull more panels, you might find hidden goodies, especially if the PO or whomever was too lazy to pull out the DAT cabling.
Engine: 3.8, 3.4
I thought as much, wish I knew where the other ends were, might be able to just use those things when I finally get around to finishing the audio system...so far I wired in cd player and some 6x9s, still got to get some 4x6s in though...but atm working on other areas of the car..
I know one of the PO's had put JVC speakers in, cause the front had 4x4 speakers in it, but mounting plates for 6x9s, plus the speaker leads had been spliced with different speaker wire. They were old, crappy and low watt speakers though, one of them blew up after about 1.5m of godsmack,lol.
Old Jun 28, 2010 | 08:36 PM
Engine: 3.8, 3.4
Well the stock radio was in there, can't remember if the wires had splicing or not though but it didn't appear to have been removed, though I guess it probably was if they had all that in there, But it didn't have any kind of adapter plates or anything in it...usually people leave those in I would think, since they're a pain to get out and won't fit a diff type of car anyway.
What is an HU or CDC? And I don't think anything else was left, all my trunk panels aren't attached so much as they are just kind of sitting there...but I'll have to double check that nothing else is in there.
Old Jun 28, 2010 | 08:48 PM
Engine: 2.7L V6
Axle/Gears: 4.41
HU: HeadUnit
CDC: CD Changer
Some adaptor boxes can be hidden under the console, seats, even in some of the space behind the dash. I hid my iPod adaptor under the console.
Old Jun 28, 2010 | 08:50 PM
Engine: 3.8, 3.4
Hmm, shouldn't part of it be visible though? And I actually figured out the acronyms on my own after I thought about it a minute,lol. Going to have to practically rip apart my interior now to see if anything good is in there,lol.
Old Jun 28, 2010 | 08:55 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Nothing except the adaptor cable for whatever device (iPod adaptor, for instance, maybe nothing for things like Sirius and XM adaptors) may be visible if installed properly. My roommate (while I was in school) had a Kenwood a buddy and I installed into his car with the iPod adaptor. The only visible part of the install was the cable for the iPod. We hid the adaptor box and the cables in the huge space behind the HU and HVAC controls (he has/had a Kia, the interior of which is mostly empty space behind the dash).
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
mx127
Aug 10, 2015 08:13 AM
