can a analog guage cluster fit into a 91 firebird?
Old May 14, 2010 | 03:15 AM
cboder218's Avatar
Car: 91 firebird
Engine: 327 .30 over with mild cam
Transmission: built turbo 350
Axle/Gears: factory
hello, another noob here... im sure this question has been answerd before. but i cant seem to find it. i have a 350 trans in my 91 and of course the speedo wont work (analog and electric i know.) but what im wondering is instead of putting one of them ugly and extra weight of a rear end mounted set up could i just swap the speedo or entire cluster from an older analog and put it in? has any one did this or is it to much work? i know the speedo dont go that high on the mph scale but im thinking ill only use it one the street, when i kick it down speeding is speeding as long as i know im doing 35 when i want to..lol
Old May 16, 2010 | 09:15 AM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
Re: can a analog guage cluster fit into a 91 firebird?
You can definitely put in a cable driven speedo into your existing cluster. You may even be able to swap your entire cluster but I'm not sure if all the wiring matches up. The connectors are the same but you may have to re-pin some of the wiring.
Old May 16, 2010 | 06:32 PM
cboder218's Avatar
Car: 91 firebird
Axle/Gears: factory
well thanks for the imput im gonna go hit the junk yard to look for a cluster ill try to put the speedo in but if i have to swap the entire cluster thats cool. thanks agan for you help
Jeremys87
Jul 14, 2022 09:08 PM
evilstuie
Apr 14, 2016 08:52 PM
355sbcTPI
Aug 19, 2015 04:38 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
tnrednneck
Aug 13, 2015 08:57 AM
