drive or overdrive?
Old May 22, 2010 | 08:57 PM
majormetallica's Avatar
drive or overdrive?
in my 1985 z28, is the d with the box around drive or overdrive? what is better for city driving overdrive or drive?
Old May 22, 2010 | 09:01 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: drive or overdrive?
the box is Overdrive... the box simply IMO is an "O" ... .. for city driving either or... I think...
Old May 22, 2010 | 09:04 PM
rshumaker's Avatar
Car: 1991 Camaro Z28
Engine: 5.7L 350 L98
Overdrive. "O" around the D, like KNBlazer said. Best to use OD for most situations unless going down steep hills or needing extra power in short situations-- then use D, 2, etc. (engine will run higher rpms under load because your transmission isn't shifting into the highest gear.)
Old May 22, 2010 | 09:11 PM
thanks so much!
Old May 22, 2010 | 09:22 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I have heard if your not going over 40 to use D but I find my car feels weird and restricted as if it's slightly pulling back or shimmying when you come to a stop. I also find that 700r4's just shift themselves if you try to use 1st or 2nd. Go out and try it for yourself. It will shift itself long before you put it into the next gear manually.
Old May 22, 2010 | 11:43 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Personally I only use "Overdrive" getting on and traveling at highway speeds. "Drive" for around town. Just feels better to me.
Old May 23, 2010 | 12:48 AM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
mine doesnt shift itself at all when in gears lower than D, found that out when i hit red line in first! i also discovered at the same time my red line is like 6200 RPMs at the same time
Old May 23, 2010 | 01:19 AM
JackRs's Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 Soon to be 3.4 :D
Transmission: Auto 4-Speed
would driving only in "O" hurt anything?
Old May 23, 2010 | 08:42 AM
rshumaker's Avatar
No, I wouldn't think it would ever hurt. Most of the population only ever drives in OD. The transmissions are designed to work that way. Basically, in OD the transmission does all of the thinking for you of when to shift. The only time I could think of doing harm is if you were towing a trailer or anything heavy. Then, you aren't "supposed" to us OD especially if it's a heavy load.
Old May 23, 2010 | 08:48 AM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Maybe its older 700r4s? I know for sure ive been in my car which is an 86 and a 88 iroc and they both shifted into 3rd before I wanted it to. I was not able to redline at all.
Old May 23, 2010 | 11:52 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Its also a shiftkit thing. If you've had a transgo shift kit installed it'll hold the gear selection in 1 or 2 until the motor blows up, the rev limiter kicks in, or you let off.
My old L98 saw 6500rpm once at the dragstrip because I had it in 1st. (can't remember why, D is just better)
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 21, 2015 12:39 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
