Help - How to remove seat belts??
Old May 26, 2010 | 01:45 PM
leedavidalan's Avatar
Hey guys, I'm thinking of going back to the junkyard to get some seat belts, front and rear. What exact tool or what size wrench or what have you, do I need to remove them? Please help. Thanks people
Old May 26, 2010 | 05:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Help - How to remove seat belts??
13mm - wrench and socket (short socket, not deep well) for the fronts - I think rears take 13mm as well.
Fronts - move seat all the way forward, get the rear two nuts, then move seat back, get the front two nuts.
Rears - under the center front edge of the seat cushion, there's a bolt - remove it and the cushion comes out. Then the backs are held at the lower outside corners.
BUT ... you should never go to the JY without a complete basic set of tools - there's no telling what you might find!
Old May 26, 2010 | 06:23 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
check the topic "seat belt replacement, how much work?" a couple spots down. I think that will help tremendously.
Old May 26, 2010 | 07:02 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Seat belts are held in by torx bolts T-47 or T-50 and I believe 13 mm bolts
Old Jun 7, 2010 | 10:12 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
I've done many seat belt set removals and from my success, the following has worked well for me.
You'll need a ratchet and a T47 bit. Bring some WD40 or PB Blaster with you, as since there is moisture present in these cars a lot (especially once they start living in a junkyard), many times, the bolts will be rusty - most noticeably the rear seat belt receiver bolts. After letting the spray penetrate a few minutes, seat the bit and then gently tap the top of it with your ratchet to give it a good fit (and also to prevent stripping). I usually push down on the ratchet with my left hand as well while turning it the first few times.
Old Jun 7, 2010 | 10:25 AM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Sometimes the seatbelt bolts have been thread locked in. I usually try to find the longest handled ratchet I can, to help with leverage.
Old Mar 2, 2011 | 10:54 PM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
How do you remove the rear seat belt trim that covers the retractors?
Hawks calls them Rear Seat Lower trim:
Old Mar 24, 2025 | 05:53 PM
JessejamesV's Avatar
Thank you. I followed your advice and it worked. I ordered the correct part off Amazon.
It requires a larger socket attachment which I had.
I was so happy when it loosened!
After 40 years, I was not sure I would be able to get it to move.
I got the new part (brand new) off ebay.
Old Mar 26, 2025 | 07:25 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Seat belt bolts in the floor are Torx Plus, not Torx. That's why y'all are having so much difficulty, you're using the wrong tool.
Old Mar 26, 2025 | 07:34 AM
This worked perfeclty:
Amazon Amazon
Old Mar 26, 2025 | 01:14 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
No, you just used it not knowing any better.
TP45 (Torx Plus) is the right tool. You will find it a lot easier to loosen and tighten the bolt, and without risk of rounding the head.
Old Mar 27, 2025 | 05:22 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Thanks for this info. A lifetime in auto repair, and I had never heard of Torx Plus. Learn something new everyday. Just wish that day had been about a month or so back! Some good reading here. https://www.finepowertools.com/hand-...-vs-torx-plus/
I'll have to order one of these for the re-assembly.
Old Mar 27, 2025 | 05:32 PM
BURD's Avatar
Most are rusted in, especially in the floor, you won’t get them out at a junk yard
Old Mar 27, 2025 | 06:14 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Those M12 floor bolts have special tightening torques too,
26-35 lb-ft
I set my wrench in the middle at 31 lb-ft
kawaslut
Feb 22, 2015 11:41 PM
RS Reaper
Sep 24, 2011 11:36 AM
Quick-IROCZ
Jan 21, 2006 05:40 PM
krazycracka55
Jun 27, 2002 12:08 AM
ripyaone
Mar 6, 2001 10:00 PM
