Auto shift knob removal??
Old Jul 1, 2010 | 10:52 AM
Military Clone's Avatar
Car: 1984 Berlinetta
Axle/Gears: 3.08
Auto shift **** removal??
Hey guys i need to remove my shift **** in my 84. how the heck do i get it off.
Old Jul 1, 2010 | 12:07 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: Auto shift **** removal??
To remove the ball shifter,first thing you do is pull out the button.Once thats removed if you look inside you should see a C type clip that attaches to the top of the shift lever.You need to pry that clip off the lever and once thats done the shifter ball will slide off.
Old Jul 1, 2010 | 02:18 PM
rednekwizard's Avatar
Car: 1986 Z-28
Transmission: 700-R4
Or do like I did and force the shift ball down the shifter then take the snap ring off with a set of snap-ring pliers.
Old Jul 1, 2010 | 03:00 PM
my82roc's Avatar
The shifter ball is not ment to slide all the way down on the lever.It should have a small metal tab on the inside that locks it on the shift lever and keeps it from falling down
Old Jul 1, 2010 | 03:36 PM
Axle/Gears: 3.08
I have the square one and that would explain why i dont see a clip on mine.
Old Jul 1, 2010 | 10:36 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If you have a later model square shift **** there's a thing that looks like a giant staple on the front of the lever below the **** that you pry out
Old Jul 1, 2010 | 11:02 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
I have a 84 also and there is a snap ring under the button to
release the ****.
Yours could be different and have the "giant staple" holding it
on. Check out this pic. and note the arrow pointing to the
staple:
http://i3.photobucket.com/albums/y94...ftknob001a.jpg
Old Jul 1, 2010 | 11:20 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
BTW............If anyone needs a new staple to hold their shifter **** on these guys have them:
http://www.moderndaymuscle.com/inc/sdetail/645
Old Jul 4, 2010 | 04:25 PM
WCinn3's Avatar
Car: 84 Camaro Z28 Roadster Convertible
Engine: Jasper 350 crate
Axle/Gears: 373
Hi all,
New member. Just bought a 1984 Z28 Convertible Roadster (2 seater Autoform Mod). If I say anything stupid, it is because I am new to this (been a 69-70 Mustang guy all my life-but a great car is a great car). My ball DOES slide all the way down and I do not see a spot for the small metal tab. Any photos of that and is it a replacable piece?
-Bill
Old Jul 4, 2010 | 06:26 PM
WCinn3's Avatar
Axle/Gears: 373
I am trying to track down the c-clip for this shifter if anyone knows who sells them
-Bill
1984 Z28 Roadster convertible Auto Form Conversion
Old Jul 5, 2010 | 11:50 AM
WCinn3's Avatar
Axle/Gears: 373
-Bill
Thanks anyway. I think I found it myself.
Click here: 1970-1981 Camaro Trans Am Shifter handle retainer clip: eBay Motors (item 350210254837 end time Jul-29-10 13:47:34
Company says it will fit.
Bill
Old Jan 23, 2011 | 09:37 PM
RAM-0108's Avatar
Car: 87 IROC-Z
how do you get off t5 shift *****? I have tried everything to get mine off but nothing works. I dont know what im doing wrong, because the shift **** on my 5 speed isn't stock, so its been messed with before. any ideas?
Old Jan 23, 2011 | 09:48 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
T shift ***** are threaded on. Unscrew counter clockwise, same direction almost everything unscrews.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
