Piece in radio compartment
Old Jul 3, 2010 | 03:54 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
I'm trying to instal a Pioneer DEH-6200BT into my firebird, and am having a problem with fitment. The reason this is on the interior section is because I have a question about the piece that its hitting. There is a thick piece of plastic with a hole in it that the heatsink is making contact with (pictures to come soon). Almost looks like a vent or something. Can this piece be removed? I'm about to hacksaw the thing. thanks
Old Jul 3, 2010 | 04:07 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Re: Piece in radio compartment
Heres the picture.
Old Jul 3, 2010 | 04:09 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
it can come out. there's usually a nipple on the back of the stock radio that sits in that hole to give some additional support in the back. my 89 rs had a metal bar instead of the plastic, pulled out without any ill effect.
Old Jul 4, 2010 | 12:03 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I wouldn't take it out... That thing is the center part of the console heater ducts. Only take it out if you want hot air blowing crud all over your new headunit during the winter or cold months (if you drive the car then).
I notched mine out for my stereo a long time ago and haven't looked back yet. Set the stereo brackets up so that the back of the HU just butts up against the duct, mark the duct with a marker, paint, or wite-out, and cut out a slot the height of your CD player all the way across and about half an inch deep. I used the same size hole for 4 CD players and they all fit fine, flush with where the old stereo sat. You can remove the duct to cut it, there's 2 screws on the bottom and 2 on the top. Just don't break the pod with the duct out... The duct is also a structural support for the frame of the pod.
PurelyPMD
May 5, 2016 04:57 PM
Justins86bird
Sep 27, 2015 09:43 AM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
