Arm Rest Question
Old Jul 27, 2010 | 06:20 AM
jpearsall187's Avatar
Arm Rest Question
Anyone know what the difference is between the 82-87 arm rests and the 88-92 arm rests? Do they require different hardware/plastics to attach to the door? Thanks
Old Jul 27, 2010 | 08:28 AM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Re: Arm Rest Question
You don't say which ones you are trying to install,so I will tell you what I know. The later style is more rounded and has no style line, the part that mounts up by your door handle is shorter than the older style and therefore requires a shorter screw. There also is no trim ring on the later style.
Hope this helps.
Old Jul 27, 2010 | 12:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
They will swap back and forth no problem. My 1992 arm rests were coming apart, and I replaced with the older ones.
RedLeader289
Jan 22, 2016 03:05 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
3rdgenparts
Aug 8, 2015 07:09 PM
