84 Berlinetta Digital dash swap.
Old Aug 16, 2010 | 09:58 PM
1985Z28camaro01's Avatar
Car: 1985 Pontiac Firebird Trans am
Engine: 305 V8 4BBL (LG4)
Transmission: T5 non WC
I have been looking around for a while online and have not found any real answers. I would like to know if I can swap in an analog cluster from like a 1985 Z28 or something into a Berlinetta with a digital dash without having to do any crazy modifications or to be honest any modifications at all. I don't really like the digital dash it doesn't suit my taste plus it doesn't really work so any input would be much appreciated.
Old Aug 16, 2010 | 10:18 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Re: 84 Berlinetta Digital dash swap.
I don't see how it wouldn't work. I do know that GM likes to change configurations. For instance, i Put an '84 Column in my '82. you would think it would just hook right up, but it didn't. they changed the wires around. Physically, it should fit fine. you'll just have to do the research on which wires go where to make it work. you will likely have to cut your Original Wiring harness.
Old Aug 17, 2010 | 04:44 PM
Turns out i read the add wrong i just purchased this car i haven't looked at it personally my friend took a look at it for me because it's kind of a treck from where i live but i read the add wrong it has the analog mph and km/h gauges and i guess the z28 cluster should just swap right in. I'll probably have to just run wires for the tachometer i suppose.
Old Aug 17, 2010 | 06:57 PM
383 Power's Avatar
Even with an Analog to Analog swap, your wires could be in different locations. Like i said, they like to change things. Check it out first. There may already be exsisting wiring there for a Tach.
Old Aug 17, 2010 | 09:33 PM
Thanks a lot for your help. I'll take a look i hope it's all the same under there. When i get the new cluster i'll try to get one that is either the same year or as close as possible to 84 just to make it easier on myself.
Old Aug 18, 2010 | 12:23 PM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
If anyone would know I'd think the guys at this site would. Email them and tell them what you wanna do. Many many parts available here too. http://www.berlinetta.info/media.htm
onthedownlow.
Old Aug 18, 2010 | 09:44 PM
Thanks a lot. I'll do that because i want to change some things around but use other Camaro parts so it looks stock.
MantyZ28
Nov 8, 2015 06:54 PM
manifoldsrme
Sep 17, 2015 11:40 PM
gta_knight
Sep 17, 2015 03:48 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Stryker412
Sep 7, 2015 09:11 AM
