Gauge cluster ?
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Gauge cluster ?
Hi I am wanting to replace my gauge cluster since the rpms don't read correctly and was wondering if I replace it with one that works if that would fix it or would it still be the same.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Gauge cluster ?
JamesC
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Gauge cluster ?
https://www.thirdgen.org/forums/elec...meter-fix.html
https://www.thirdgen.org/forums/elec...aayyy-off.html
Do those help?
From what I know capacitors dry out with age, so it may be possible that they're all going to be about the same. I've noticed that a lot of Berlinetta electronics are that way but it's more from physical wear, and cold solder joints.
Do those help?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Gauge cluster ?
This is the cause of 95% of GM's electrical problems, and is ALWAYS the first thing I address whenever I'm facing electrical problems.
In the specific case of the tach though, that seems to be most commonly a bad resistor on the DIP chip attached to the small board beneath the tach. The links that Scorpner provided will give you all of the information you need to fix that problem.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Gauge cluster ?
Or how are the aftermarket tachs installed I seen them for as cheap as $10 on craigslist.
Re: Gauge cluster ?
Why not fix what you've got instead of slapping some cheap POS in front of your mal-functioning stock piece?
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Gauge cluster ?
I am just wantin to change it since I don't have any idea of how to fix it, and I seen the sticky but I don't understand all of those things.
