Interior Paint
Old Oct 1, 2010 | 10:11 PM
vetchris54's Avatar
Interior Paint
Anyone know any company eg. (Classic Industries) that carries aerosol interior paint for painting (refinishing) the plastic interior trim parts? I am needing to repaint all my interior trim parts to the factor gray. Thanks.
Old Oct 1, 2010 | 10:14 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Re: Interior Paint
If you clean the panels and let them dry , prep them really good, you can always try krylon fusion paint, depends on how picky you are
Old Oct 1, 2010 | 10:21 PM
lillee64's Avatar
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
Re: Interior Paint
vinyl dye from autozone is the best and most durable. wont scratch off because it soaks into the material, u really have to do some sanding or scratching to get it off.
Old Oct 1, 2010 | 10:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Interior Paint
eastwood.com
Old Oct 1, 2010 | 10:58 PM
vetchris54's Avatar
Re: Interior Paint
Awesome! Thanks so much for the help
Old Oct 2, 2010 | 12:47 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Interior Paint
Any full line auto body jobber/supplier has plastic trim paint/dye in stock.
Both in spray cans and bulk.
Old Oct 2, 2010 | 02:35 AM
gen3guy's Avatar
Re: Interior Paint
sem makes good stuff
when we paint interior parts at work we very lightly scuff them the wash with thinner right before you paint. apply the thinner to a rag and wipe on
Old Oct 2, 2010 | 01:38 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Re: Interior Paint
clean them real good use some Duplicolor adhesion promotor then some of their interior plastic/vinyl paint
Old Oct 5, 2010 | 08:58 PM
hodder's Avatar
Car: 83 z/28
Engine: 305 4 barrel
Re: Interior Paint
i just finish try ppg product sc series i had it color matched to the origanal interior and was very happy with the result. i only paint the tire cover. just to see how it would come out. its actually a dye and price at $60.00 a quart. i estimate that a quart should do the whole interior. i followed the spec sheet that is available online at ppg and did not use any plastic adhesion promotor. i washed it with dish soap scuffed it then clean it wax and grease remover. when i spray i dust it on.
Old Oct 8, 2010 | 12:29 AM
haroanarchist's Avatar
Car: 87 formula
Engine: LG4
Re: Interior Paint
From experince painting plastic parts on my bike i would recomend krylon fusion. Any paint will scratch and ware off so you shouldn't paint any were you touch alot.
A side note if you sand the trim you will make it smooth and funny looky just clean and use a scotch pad lightly.
Old Oct 11, 2010 | 11:52 AM
levin cris's Avatar
Re: Interior Paint
just go to a paint shop, they can usually mix some up for you. Some places can mix it up into a spray paint can, too.
Vintageracer
Jan 10, 2020 05:33 PM
Hawk312
Aug 22, 2017 08:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
