Car has been in the shop for 2 weeks because of steering column, stuck.
Old Nov 15, 2010 | 02:38 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Basically the pivot pin housing is worn out, so the wheel has the 7 o'clock slop. They replaced my column, and the replacement column had the same exact problem. The shop can not find the housing anywhere and already I'm in $730. Can anyone help me out here? It's a 90 (airbags)
Old Nov 16, 2010 | 11:34 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Car has been in the shop for 2 weeks because of steering column, stuck.
Sure its not the pivot pin thats worn out.
Old Nov 16, 2010 | 12:23 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I'm a little confused when you say the housing is worn out. Is it the Torx bolts down inside the column that have come loose and is allowing the wheel to wobble or is it a seperate problem?
Old Nov 16, 2010 | 02:22 PM
Mr Froman's Avatar
Basically all I saw from the few minutes I was in the shop was an ovaled out hole where they said the pivot pins sit and they said they would try to find another column.
I was checking these out: http://www.flamingriver.com/index.php/products/search
Old Nov 24, 2010 | 09:47 PM
west1nm's Avatar
Car: 91 Z28 Vert
Engine: LS3
The ovaled holes are a common problem on these (thus creating the 7 o'clock slop). For a temp fix, you can fill and cover with epoxy to minimize play. I have dine this on mine with great success. Just make sure your don't use the steering wheel as a support when entering/exiting the vehicle.
Old Sep 7, 2012 | 11:38 PM
kd5bwp's Avatar
I know this is an old thread but I have the same problem and found every car I search in every junk yard possible has the exactly the same issue... Is there a part number that can be pulled and replaced? Or is there a basically drop in replacement steering column?
Or is there another thread that relates on how to fix this common problem? At this point I'm wishing I didn't have tilt.
Old Sep 8, 2012 | 03:08 PM
Mr Froman's Avatar
Looking back, I wish I would have just welded a washer to the column to make it round again. Something simple but effective.
Old Sep 8, 2012 | 03:45 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
If anybody needs column parts, pics, diagrams, instructions check out
these guys:
http://www.steeringcolumnservices.com/
Old Sep 12, 2012 | 05:47 AM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
these guys:
Thank you for that site... I had a column apart today and EVERY parts store in town didn't have what I needed. Looks like I am making a order in the morning.
Old Sep 12, 2012 | 10:17 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
No problem!
I needed that turn signal pivot arm piece. I searched everywhere for one new or
used ! I stumbled onto that site on a Cadillac forum.
Enjoy!
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheExaminer
Aug 26, 2015 04:59 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Bull86
Aug 10, 2015 05:43 PM
