dash board problems
Old Nov 19, 2010 | 08:06 AM
skolland1018's Avatar
Car: 88' sport coupe camaro
Engine: 5.0l v8
dash board problems
My dashboard has been shaking really bad is there anyway to fix it?
Old Nov 19, 2010 | 08:25 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: dash board problems
check all your screws along the windshield and the nuts by the door jambs.
Old Nov 19, 2010 | 02:54 PM
Engine: 5.0l v8
I gave it a try and my dash is still shaking
Old Nov 19, 2010 | 02:57 PM
1981LT1's Avatar
Engine: LT1; LT1
Are the mounting tabs broken anywhere?
Old Nov 19, 2010 | 03:16 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
Balance your tires? Is it when your driving or is it loose at a stand still and you can wiggle it?
Old Nov 21, 2010 | 11:58 AM
Engine: 5.0l v8
at a standstill i can wiggle it
Old Nov 21, 2010 | 12:33 PM
ChromePhoenix's Avatar
Car: 85 Trans am
Engine: 350 carbed
Axle/Gears: 9 bolt rear disk
Just the dash pad or is it the whole assembly? its possible the plastic mounting tabs inside the dash are loose or broken.
Old Nov 26, 2010 | 11:28 PM
Engine: 5.0l v8
its just the dash pad thats shaking really bad
Old Nov 27, 2010 | 12:20 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I second checking the mounting bolts to the plastic dash frame.
Old Nov 30, 2010 | 12:43 PM
Engine: 5.0l v8
The mounting bolts are right near the windshield right?
Old Nov 30, 2010 | 01:38 PM
1981LT1's Avatar
Engine: LT1; LT1
yes
Old Nov 30, 2010 | 02:04 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The dash pad is basically foam & easy to strip the screw holes.If thats the case maybe some crazy glue or epoxy or something to fill the hole so the screw can bite.
If its the dashboard, there are 2, maybe three nuts under the dash pad at each corner by the b-pillar.Plus, maybe one in the center.There also two under the dash at roughly each corner.
Old Dec 6, 2010 | 10:24 PM
Engine: 5.0l v8
Its just my right side of the dash that is shakin and makin a weird sound i feel like my speaker might be loose
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
overdriv
Aug 20, 2015 03:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
