4th gen shifter with 4th gen AUTO upper console
Old Dec 4, 2010 | 08:16 PM
82z28man's Avatar
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
Ive done alot of searching and cant find a clear answer, will a 4th gen auto shifter work with a 4th gen auto upper console. I already have a 4th gen dash and have the console but am swapping back to an auto. I already cut the floor shifter bracket previously and am wondering if I can just bolt a 4th gen shifter directly to the floor to lower the height.
Old Dec 5, 2010 | 09:29 AM
Firebat's Avatar
Re: 4th gen shifter with 4th gen AUTO upper console
I know I've seen it done on here before but couldn't find it with a search. I think the only way the 4th gen AUTO console will fit into a thirdgen is by using a 4th gen auto shifter.
Old Dec 5, 2010 | 12:23 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
As long as everything is the same (all 4th gen) you should be fine.
Old Dec 5, 2010 | 01:14 PM
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
it'll fit altho i used an auto console with 3rd gen shifter set up, because i wanted the 4th gen auto upper console for a different reason.
either way- i simply mod it to work, came out pretty sweet
1992 Trans Am
May 10, 2023 07:19 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Casey Meyers
Mar 2, 2016 10:46 AM
