Is this steering column broken? (not loose?)
Old Dec 7, 2010 | 05:17 PM
Evo_Spec's Avatar
Hey guys, i picked up a 87 camaro a couple weeks ago from kijiji that the seller listed needs new steering column.
So i looked up steering column fixes in google and found that the steering column being "broken" was common and just needed to be tightened up.
The car ran great and started right away so i bought it as an "easy fix" car that i could drive around for a little while, i drove it home with the steering wheel flopping around everywhere and parked it and never got around to actually fixing it until recently.
i followed directions on fixing the steering column in a post here and some other one's and once i got pretty much everything off i realized that it seems to be actually broken and not just loose.
so basically i wanted your guy's opinions/experience on weather this is actually broken or not?
i assume i'm going to need a new steering column but don't look forward to doing, hopefully someone in Edmonton has one? (and can help me install it too? XD)
It can be pulled in or out with a little effort too....
Thanks for any help in advance
Old Dec 7, 2010 | 09:46 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: Is this steering column broken? (not loose?)
Hello Evo_Spec!!
You took a hell of a chance driving that car home with that broken steering column!!
There is a place in Edmonton called David T's he does Camaros/Firebirds parts, and whole cars!!
Call 780-454-3330
or www.davidt.com
P.S. Welcome to the forums!!
Old Dec 7, 2010 | 11:10 PM
Evo_Spec's Avatar
Originally Posted by 87IROC-DAN61
Hello Evo_Spec!!
Call 780-454-3330
or www.davidt.com
Yeah, it wasn't the funnest drive i've ever done.
Thank you very much for the welcome and information, i'll give him a call in the very near future, you have no idea how much that helps me.
Old Dec 8, 2010 | 01:44 AM
Hello Evo_Spec!!
Let me know how this David T place is, I have been known to drive a bit to get things, especially if it's worth it!!!
wigmobile
Feb 26, 2025 02:56 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
