shoulder guide replacement, need help
Old Dec 11, 2010 | 05:35 PM
PDXRS's Avatar
Car: 91 camaro RS
Engine: 3.1 v6
I bought a set of 3rd gen seatbelt shoulder guides to replace the broken ones i had on and i can seem to figure out how to get the belt through the damn thing! I unbolted the bottom but it's far too big and the top one i have no clue how to take the top one out. Please Help! I have a 91 camaro RS
Old Dec 11, 2010 | 06:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: shoulder guide replacement, need help
What do you mean by shoulder guide? The plastic ear screwed to the side of the seat that the belt passes through?
Old Dec 11, 2010 | 10:39 PM
PDXRS's Avatar
Car: 91 camaro RS
Engine: 3.1 v6
yepp, the plastic piece. how are you supposed to get the belt through it? whats the best way to do it?
Old Dec 11, 2010 | 10:48 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello PDXRS!!
Undo the screw!!
The guide has two screws, the first one splits the guide, the second one removes it from the head rest!!
The first screw is what you want, then slide the belt out of the loop!!
It's really simple!!!
Old Dec 12, 2010 | 05:57 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Actually, I don't think yours come split, but a fine cut saw through the mounting plate between the two screws will work for you.
Old Dec 14, 2010 | 10:57 PM
Hello PDXRS!!
with
I searched out "your" seat belt guides on a "popular internet shopping site" and found a pair of the guides that you are talking about for sale by Hawks ThirdGen Parts, and they cut them off of the seat belts in between the two mounting screws!!
They did a good job also, looked real good!!
P.S. I guess that will teach me to "RTFQ" first, and make sure that I really understand it, before I post a wrong answer!!
Old Dec 16, 2010 | 06:41 PM
PDXRS's Avatar
Car: 91 camaro RS
Engine: 3.1 v6
Thanks for the help! I didn't want to waist the replacements i bought
Cameeeero
Sep 18, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
chazman
Aug 22, 2015 02:01 PM
Fronzizzle
Aug 9, 2015 01:15 PM
BrianI
Aug 9, 2015 11:52 AM
