Dynamat Door Panels??
Old Jan 20, 2011 | 09:50 PM
Guest
Guest
Posts: n/a
I have i think 4 sheets of dynamat i just got done fixing my door locks.
If your door locks dont work spray some wd-40 on the rods and the motor to unlock it.
But i was wondering What and where can i put the dynam mat to sound dead the doors need a idea.
Old Jan 20, 2011 | 10:01 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Dynamat Door Panels??
Had the same problem when I used SmittyMats , then it hit me, put it on the back side of the door panel cover, not on the door. As you can see them metal rods for the handle n lock would need trimmed around. Plus if you ever had to go in for something, you would have to peel it back off.
Worked out great, still block sounds.
If its an outter door skin noise, you cover the inside/backside of the outter door skin through the holes in the inner structor.
Old Jan 21, 2011 | 12:37 AM
87350IROC's Avatar
Car: 87' IROC
The door skins are very important. They are thin and not supported by creases like the door skeletons. They ring like crazy. Its not a lot of fun, but you can get 80% of the door skins covered by going through holes in the skeleton. I put two layers on the skins and one on the skeleton.
Also, while you are in there secure the power window motors. That vibrate like crazy without extra support.
Old Jan 21, 2011 | 12:38 AM
1BADZ28SD's Avatar
Car: 1991 Camaro Z28
Engine: 5.7Liter HSR
nice im doing that to my car
Old Jan 21, 2011 | 05:47 AM
Guest
Guest
Posts: n/a
Ok I'm doing that when gets a little warmer and dynamat can stick this sounds and looks amazing and i got this horrible rattle in the right door I know what it is now.
You helped out alot thanks man.
Old Jan 21, 2011 | 06:16 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
when I did mine I was putting on a new door and as such hosed down the inside of the door with a whole monster can of rubberized under coating so it stayed nice and rust free inside so that took care of it for me. But you do need something in there to take away the tiny sound of sheet metal. Like having no head linner, that roof is noisy. Was the first thing I covered SM
Old Jan 21, 2011 | 10:19 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
I put MegaMat on my inner door skins. works very well. very nice improvement to sound control, vibrations, and sound quality from the speakers.
Old Jan 22, 2011 | 08:25 AM
Guest
Guest
Posts: n/a
Sounds Awesome I can't Wait it makes people think also when you want to sell your car it sounds like it's brand new on the inside.
Old Jan 22, 2011 | 09:32 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Dynamat the outer door panel first then work your way in.
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
May 7, 2016 06:23 PM
tglennon11
Sep 23, 2015 05:30 PM
NiG
Sep 7, 2015 11:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
