speedo cable and buzzer problem
Old Jan 28, 2011 | 06:41 PM
fonzie85's Avatar
Car: 89 IROCZ
Engine: Forged 347 LS1
Transmission: Built 4L60E with 4k stall
Axle/Gears: 4th gen w/ 3.42 gears
I took the cluster out of my 89 iroc to fix the tack. Ever since i took it out i notice the door/light buzzer stays on all the time whan the car is running. It didn't do this before any body have any ideas as to why this might be?
The second thing is my speedo cable... i got it back on and it half work and makes a grinding sound, i assume this is bc i don't have it on right but is there a way to tell or a trick to putting it back on?
Thanks,
Old Jan 28, 2011 | 07:56 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: speedo cable and buzzer problem
Its a door light and the buzzer staying on?
Does the door light stay on when the car is not running and the key is out of the ignition? Does the buzzer stay on when the key is not in the ignition?
Maybe one of you door jamb switches is out of adjustment and the door is not conatcting and pushing it in. O a wire for that circuit got grounded.
Check the door jamb swicthes. There is the pin or button that the door makes contact with. It is inside of a sleeve and the sleeve is inside the nut. That sleeve pulls out or pushes into the nut for adjustment.
You can push on the button and if the light goes out then that is the case. To adjust, just use some pliers, don't crush it, and pull the sleeve out some. When the door closes it will push the button and then the sleeve if its out to far.
Old Jan 28, 2011 | 09:41 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Sounds like the cluster is not on all the way.If you dont tighten the 10mm nuts (2) at the bottom (in the warning light ports).You will have all sorts of wierd problems.One of them being the buzzer not shutting off.
Speedo noise could be the cable is not fully seated.You should have heard a click if the cable seated correctly.You should not be able to pull it off either if its on right.
Old Jan 29, 2011 | 08:54 AM
fonzie85's Avatar
Car: 89 IROCZ
alright thanks "84 1le" i think that prob answer bot my questions ill check those things and let you know what i find out.
Old Feb 5, 2011 | 01:20 AM
fonzie85's Avatar
Car: 89 IROCZ
well i took the cover off to check the bolt and they were tight and the buzzer is still on the the whole time while the car is running. any other suggestions? I don't know if this matters or not but I did start the car once or twice when the cluster was all the way out.
Old Feb 5, 2011 | 07:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I agree with 84. I'd remove the nuts, pull the cluster out, reposition it, then reseat it. I doubt that the cable is fully seated either. With the cluster in place, find the cable housing, make sure the cable itself, which is rectangular, is aligned with the female speedo head so that the cable actually fits into the slot. Push until you hear a click.
JamesC
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
beachrodder
Aug 7, 2015 04:27 PM
