98 guage cluster into a 91 dash?
Old Feb 2, 2011 | 12:19 AM
5.SLOW's Avatar
Car: 1991 Z28
Transmission: 700-R4
Axle/Gears: 10 bolt Disc/Posi
Have a few finishing touches to add to the "show" side. Going to fabricate a way to mount it in the dash and wire it up within the next 2 weeks.
Old Feb 2, 2011 | 02:59 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: 98 guage cluster into a 91 dash?
That looks pretty good! Looking forward to final install pics.
Old Feb 2, 2011 | 03:05 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i wanna see this
Old Feb 2, 2011 | 06:07 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
are you still using a TPI engine or are you LS1 swapped?
Old Feb 2, 2011 | 08:46 PM
5.SLOW's Avatar
Car: 1991 Z28
Tpi. I wish i had the money to swap a ls1 in it.
Old Feb 3, 2011 | 12:50 AM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
awesome, post up some "during" pictures of how you did this, i hate the stock cluster, would love to do this swap as well. very interested.
Old Feb 6, 2011 | 06:27 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
bump, give us an update.. really want to know how this turns out
Old Feb 6, 2011 | 08:37 PM
5.SLOW's Avatar
Car: 1991 Z28
Internet has been down at the house. Im takong pics as i go. Should have an update tom or uesday for ya
Old Feb 6, 2011 | 08:45 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
how much do you have to mod for that to work?
Old Feb 6, 2011 | 09:30 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
There is a member who modded his gauge panel to fit a 98-02 gauge cluster. But I would imagine it wouldn't be too much different than this.
Old Feb 7, 2011 | 02:31 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I dont think its going to work. The Tach input signal comes from the PCM in along with fuel and check engine light. Your speedo should work if you have a voltage driven style. If you dont have the PCM to really match then, i dont think it will work. I think the 93-97 should work
Youtube Video
http://www.youtube.com/watch?v=15_XYO4GyOo
Old Feb 7, 2011 | 08:11 AM
5.SLOW's Avatar
Car: 1991 Z28
From what ive researched the fuel guage is the only one that gets a signal from the bcm. I have yet to look up the schematics but im sure i can get it sorted out and have everything working.
Old Feb 9, 2011 | 10:01 PM
5.SLOW's Avatar
Car: 1991 Z28
Got the side pieces to cover up most of the space between the guages and housing. Once i got them fairly close to the shape of the edge of the housing i superglued them to the housing. I will use some type of filler to fill the gaps and smooth everything out. Going for a completely factory look.
wiring will definitely be fun, but i have access to schematics of both cars so it shouldnt be too difficult.
Old Feb 10, 2011 | 06:26 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
looking good... cant wait to see it working.. very interested in the schematics on how to make it work
Old Feb 21, 2011 | 07:32 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
bump.. been 11 days.. whats crackin?
Old Mar 28, 2011 | 05:31 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
hey finish this..
im now going 96 LT1... would like to swap in the 97 cluster since it too used the LT1 and is the new style
Old Mar 29, 2011 | 10:12 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
I think he realized that a 98 cluster wont work.
Old Mar 29, 2011 | 10:01 PM
5.SLOW's Avatar
Car: 1991 Z28
correct. 97 will. same style, only not fed through a serial data line. Ive got a **** ton of other projects going on anyways.
Vintageracer
Sep 24, 2017 12:34 PM
tmellott89
Oct 14, 2015 02:06 PM
rusty vango
Sep 29, 2015 02:44 PM
Eric-86sc
Sep 28, 2015 11:37 AM
