Cargo Hatch Cover Curtain retract issues.
Old Feb 18, 2011 | 04:10 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I just installed a cargo hatch cover, from scratch! But now I got an issue. The curtain doesnt retract by itself. Does anyone have this problem too? If so, have you fixed it? If so, how?
Wanna see the installation? https://www.thirdgen.org/forums/inte...tallation.html
Old Feb 18, 2011 | 05:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Cargo Hatch Cover Curtain retract issues.
Try pulling it all the way out - CAREFULLY. Then see if it retracts. The square ends on the roll must not move (must be securely in the holders.
Old Feb 18, 2011 | 05:10 PM
Ok man. Ill test it out when I get home. I'm on the way to Mexicali, Mexico to eat some tacos with my wife and kids. By the way, thanks for the compliment.
Old Feb 18, 2011 | 05:36 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
it's like a old fashion window shade , must be wound up to work . first make sure it's installed with the shade opening on the top . with lt. side secure in holder & curtain rolled/layed out . lift rt. side out of holder & rotate CCW . rotate untill shade is fully rolled up . don't over due it . pull shade out & retract a few times . if it doesn't fully retract , a couple of more CCW turns on rt. side . repeat as required untill there is just lite tension on shade when fully rolled up . good luck .
Old Feb 18, 2011 | 06:03 PM
Thanks UNCLE TOM. Can't wait to get home to try it out. Ill post up the results.
Old Feb 19, 2011 | 01:07 AM
Okay. I tried out your method without any positive results. I will take some video of the proceedure and post it up on youtube so that ther ecan be a more clearer understanding of what is being done. So you'll be hearing from me tomorrow. C ya.
Old Feb 19, 2011 | 11:36 AM
Drew's Avatar
If the ends aren't supported in the car with them pushed toward the center of the shade, the mechanism won't release and let it wind back up. In other words, if you remove the shade from the car, and pull it out, it won't retract until you push the mounts in. Make sure the mounts are being pressed far enough toward the center.
It's also been discussed before that the tension can be increased. It's a coil spring that can be tightened a turn or two to increase the tension. Try a search.
Old Feb 19, 2011 | 12:04 PM
Yup. I already tried the turn to increase tension but I'm not sure if I did it right. So I'm gonna take some video and post it up to show if I'm doing it right. But ill do more searches to find more solutions to the problem. Thanks Drew.
Old Feb 19, 2011 | 06:03 PM
avilla20's Avatar
Car: 1990 rs/1986 iroc-z
Engine: Lho 3.1 v6/Lb9 5.0 v8
my iroc has the same problem, i havent tried to fix it yet, its at the bottom of to do list for my three cars. but mine is also though to pull out.
Old Feb 19, 2011 | 07:55 PM
IT WORKED!!!! I did have a little bit of a struggle when there was tension and tried to unwind the curtain to have it roll up over the rod. But after a few attempts, it made sense about winding CCW. Thanks UNCLE TOM!!!
Old Feb 19, 2011 | 10:06 PM
Bro. Its not a fix in a sense but rather an adjustment. Roll the curtain as if it has retracted while mounted. Then lower your rear seats. Remove the bar from the passengerside but do not pull it away from the cup on the driverside. Now while holding the curtain so that it wont unwind, roll the bar counter clockwise for atleast 10 revolutions. You should begin to feel resistance. Once there is noticable resistance, insert the bar into the cup. Then pull the curtain out to extend and test. The curtain should wrap up when you allow the bar to roll back up. If the curtain doesnt roll up by itself, then roll up the curtain manually and remove the passengerside and turn counter clockwise a few more times and retest. If you really need me to record a video, I will for $10...... Im just kidding. seriously, if you need video of the proceedure, Ill do it. But as for my curtain, problem sold thanks to UNCLE TOM.
Old Jul 8, 2024 | 03:27 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I'll take that video!
Old Aug 27, 2024 | 01:19 PM
Catbox's Avatar
Car: 1992 RS Camaro
Engine: 305 TBI
Im'a hafta give this a go now that the back half of the car has been put back in and the cover does not retract on its own.
Excellent advice.
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
punkmaster98
Sep 30, 2015 11:01 AM
Randomtask2
Sep 10, 2015 08:37 AM
scottmoyer
Sep 7, 2015 07:06 PM
