two questions, leaking T tops, fuze box
Old Feb 21, 2011 | 12:59 AM
H_E_L_P's Avatar
I have a 1984 z28 Camaro with leaking T-tops and i heard that a silicon spray can be used to fix them and I just wanted to get a second opinion on that.
Also my accessory fuse drains my battery and I want a cut off switch to just kill my fuse box after I shut the car off of course and what I was wondering was if any one has done this before and had some ideas on it
Old Feb 21, 2011 | 10:21 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: two questions, leaking T tops, fuze box
It's not the accessory fuse draining the battery, it's something on the accessory circuit, like cig lighter or something - trace down the problem and fix that. Until then, just remove the fuse.
The T-Tops are adjustable to a degree - under the A-pillars and B-pillars there are small screws that hold the pin receivers to the body - loosen the screws and adjust the receivers so the tops close tighter - might help.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Casey Meyers
Mar 2, 2016 10:46 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
