How do you remove the shifter knob?
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
How do you remove the shifter ****?
'84 Z28. Auto trans 4 speed w/OD. I have a ball for a shifter with a button on top. What is the trick? I would rather not buy a specialty tool if possible. I just want to clean up the shifter plate to be brighter, but I can't get it off of the shifter due to the ****.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: How do you remove the shifter ****?
there is a pin that holds the shifter to the shaft. Just need to pry it out witih a small screwdriver or somethign you can get under it and pull it out...much like a staple in a pile of papers.
Its located on the front side on the seam about half way down.
Car: 1984 Z28 T-TOP
I don't have a seam. Solid plastic ball w/solid plastic button. Ball spins freely. I think it is stock.
Car: 85 Z28 Camaro 2011 camaro LS
Engine: 350 Edelbrock Crate bored .60 over
Transmission: 400 turbo
YOU PULL BUTTON IN THE CENTER UP AND THEN THE BALL WILL COME OPFF FREELY THE BUTTON IS WHAT HOLDS IT ON
THE 91 SHOULD HAVE A PIN THAT LOOKS LIKE A STAPLE
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
91 shifter has the staple in front you must remove to free the ****. The 84 is held on by a circlip. First you pull straight up on the button and it comes right out. After that you can see by looking down in the circlip which is easiest removed with circlip pliers to fit in the little holes. After you take that out the **** comes straight up and off. Your **** spins if the tab or tabs that locate it in place on the shaft are worn down or broken off.. If you can't find a replacement and need one, I have a single tab one with good button and circlip around here somewhere I can make you a deal on. LMK, Henry
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Car: 1989 Camaro RS
Engine: V8 5.0
Transmission: Automatic
i have the same issue, but my camao is a 89 RS. I've taken out the middle plastic one that pushes down, and tried to twist it out, but it wouldn't turn or budge. I tried pulling it out and that didn't work. How can i know if it has a clip, pin or staple? Please help, thank you.
Car: 89 Z
Axle/Gears: 10 bolt 3.23
89 has the clip in the front part of the ****. Use a hook or small screwdriver in the slot to remove clip. **** will pull straight up.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
If its a automatic with the leather covered ball head it will
either (depending on year) have a staple in the front lower part
of the ball OR have snap rings on the shifter shaft under the top
cap.
If it has the staple............ Pull the staple and pull it off.
IF NOT....... you have to remove the release cap on top of
the ball and take out the snap ring then pull it off.
cap.
Car: 1989 Camaro RS
Engine: V8 5.0
THANK YOU SOOO MUCH I WILL DO THIS ON SATURDAY AND LET YOU GUYS KNOW WHICH ONE IT HAD. VERY MUCH APPRECIATED!!
Hotrodboba400
Dec 10, 2019 07:07 PM
