i need a step by step
Old Mar 24, 2011 | 08:34 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
i searched around and looked through the tech articles and i didn't see anything. does anyone have a write up or know where there is one on removing the gauge cluster on a 91 z28?
Old Mar 24, 2011 | 09:21 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
Re: i need a step by step
Remove the light **** shaft. Remove the bolts holding hush panel. Remove bolts holding gauges. Tilt steering down. Remove cluster.
Thats how I did it on my '90. I can't imagine its thats much more complicated.
Old Mar 24, 2011 | 09:43 PM
Car: 91 Trans Am
Engine: 355 TPI
alright cool....wasn't sure if the dash pad had to come off or not....thanks alot i really appreciate it
Old Mar 25, 2011 | 03:22 PM
::Andy::'s Avatar
Car: 1991 Camaro RS
Engine: 305ci TBI
Transmission: 700R4 Built
Axle/Gears: 3.73 Eaton Trutrac 10-bolt
Literally just put my dash back together tonight after fixing the over reading tach!
First thing is to remove the lower panel below the steering wheel, on ours there are two T30 Torx bolts under bolt plugs and then three lower down at the back, they are quite well hidden so have a fish around. The whole panel should drop down now.
This will reveal a bunch of bolts under the dash surround. Undo the two 1/4" - 7mm bolts that hold the surround on.
Carefully pry off the fog light switch cover (this is the lower plastic pop off panel on the outside of the surround below the head light pull switch.) With this off, look inside with a torch, about 4-5" back there is a tiny metal roundhead pin that is spring loaded. I found the best way to press this is with a long flat bladed screwdriver, gently press the pin down while pulling the light switch towards you. This takes a bit of practice but eventually the rod comes out.
With this out, with one hand around either side of the surround, pinch slightly while pulling towards you, this will eventually pry off. Turn it towards the door as this will help hook it off the steering column and around the control stalk.
Now you should be able to see a bunch of bolts. I found the best way to take out the cluster with the steering wheel in position is to remove the glass and the black dial surround.
Taking off the glass: There are 6 - 5mm bolts, two in the top corners and four on the bottom (one in either corner, and two almost hidden next to the column.) Pull the glass free.
Taking off the black dial surround: There are 3 - 5mm bolts set far back on the top of the cluster, undo and remove carefully and don't allow them to drop down the back. Pull the dial surround off being careful not to damage the reset trip button.
Now the dial cluster should be easy to take out by removing the four remaining 1/4 - 7mm bolts easy to be seen because of the white tabs they bolt down.
Reinstalling is the opposite of the above.
Hope that helps!
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Elephantismo
Feb 13, 2019 12:51 AM
Gunner242
Dec 25, 2015 04:49 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Chad Speier
Sep 24, 2015 12:32 PM
