factory steering wheel
Old Mar 31, 2011 | 09:31 AM
hartsmike's Avatar
Car: 1986 Black IROC
Engine: 305 Quadrajet
Transmission: 5 speed
Axle/Gears: 273
My IROC has a grant wheel and I am wanting to find a factory steering whell and put back on it.. is it difficult to do and how do I do it?
Thanks,
Old Mar 31, 2011 | 09:33 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: factory steering wheel
You can get the steering wheel puller from Autozone or one of the other chains as a loaner. Outside of that it's pretty easy.
If your tilt is loose you may consider tightening it when you swap. There's some threads here that walk you thru that with pics.
Old Mar 31, 2011 | 10:10 AM
hartsmike's Avatar
Axle/Gears: 273
I don't have the stick coming from the steering column to tilt the wheel.. Don't know if it had it from factory or not.. I don't see bolts to loosen up to pull it...
Old Mar 31, 2011 | 10:18 AM
naf's Avatar
naf
Then you've got a non-tilt column. Nothing to tighten.
Old Apr 1, 2011 | 11:57 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
I've done this a few times.
1. Borrow a steering wheel puller as mentioned (I got one from VIP).
2. Use a 4-star lug wrench. One of the heads will fit the bolt perfect and with the leverage you get, it will be super easy to spin off the bolt.
3. Don't forget your needle nose pliers; you'll need to remove the holding pin
4. The horn will be attached by a thin wire. Carefully slide that off
Old Apr 1, 2011 | 12:37 PM
hartsmike's Avatar
Axle/Gears: 273
Does the center cap of the Grant steering whell come off? Its got several hex bolts around the cap.
Old Apr 1, 2011 | 12:51 PM
crazymonkey16's Avatar
Car: 1990 Camaro RS
Engine: L05 TBI
Can you post a pic of the grant steering wheel? I've got one as well, and if it's similar, then you don't need to pull those hex bolts. All you'd need to do is remove the horn button. I've found a suction cup, like the ones used to attach things to windows, works well for this.
Old Apr 1, 2011 | 01:46 PM
hartsmike's Avatar
Axle/Gears: 273
Ok. Sounds good. I'll take one when I get home and post it up. Thanks for your help.
Old Apr 3, 2011 | 10:13 AM
majobis's Avatar
Axle/Gears: G92
It's a two piece setup. You'll need to remove the allen wrench screws to access the underneath. The center cap (which say's 'grant' or 'gt' or other) pops out as well.
Old Apr 3, 2011 | 10:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, the Grant wheel can't be removed with a typical puller.
JamesC
Old Apr 3, 2011 | 12:40 PM
hartsmike's Avatar
Axle/Gears: 273
I looked at it last night and popped the center out.. There was one nut in the middle.. Is that what I've got to twist out?
Old Apr 3, 2011 | 01:04 PM
JamesC's Avatar
Remove the nut (and safetly clip if there is one), then use the appropriate puller.
JamesC
backtothe80s
Sep 5, 2015 12:39 AM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
