how do I remove the dash guage cluster
Old Apr 8, 2011 | 01:21 PM
jbradhill's Avatar
Car: 1986 Camaro IROC Z28
Engine: 383 SBC
Axle/Gears: 3.75 LS
I had a temp guage that pegged 12noon and wouldn't come down. It was working fine until I switched from a mechanical to elec water pump. My car is carburated and the temp sensor is running from the front of the manifold next to the radiator hose connection. No it is not on the side of the block (std), that has a threaded plug in it between cyl 1 & 2 on driver side. I figure I have shorted it somehow, but couldn't trace it down. All the other gages looked like they were working.
So I removed the plastic front to the guage cluster and the bezel, then the vairous screws holding the panel. When I begin to pull it out, it is being held by the speedo cable and possibly some wire connectors? Also, after doing this, none of the guages work... so I am thinking something may be loose on the back of this cluster?
I checked the fuses and don't see anything blown.
Does anyone have a link to show how to remove the cluster?
Old Apr 8, 2011 | 01:29 PM
Cerridius's Avatar
Car: 1988 Camaro sport coupe
Engine: 305 TBI
Transmission: T5 world class manual transmission
Axle/Gears: i think its 3.08 ration posi
Re: how do I remove the dash guage cluster
This might help, it helped me take my gauge cluster out.
https://www.thirdgen.org/leddash
Old Apr 8, 2011 | 05:12 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
are you trying to swap in a new cluster to see if the temp gauge with that one works?
if so your old temp gauge should just unplug from the cluster its socket-ed in like a plug in the wall , you wont have to take the entire cluster out
ive never taken my entire cluster out so i cant help any further than that
Old Apr 8, 2011 | 05:22 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
All but the speedo are plug and play as has been mentioned. No need to remove the cluster. Should you choose to remove the cluster, note the following link:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Apr 9, 2011 | 07:23 AM
jbradhill's Avatar
Engine: 383 SBC
Axle/Gears: 3.75 LS
thanks everyone. I am out-of-town til Monday. I appreciate the feedback.
I don't plan to replace the cluster, unless I have to.
Originally only the temp gage stopped working (pegged vertical) and I thought that was the only problem, maybe the temp wire grounded somewhere, but couldn't find it. But after a day of trying to look under the dash, none of them appear to work any more, so I am thinking that maybe there is a main plug on the back that has come loose. So I expect to pull the cluster to check it.
Thanks for the link which is perfect for getting it out. I had seen the link on another thread, but it was broken (must have been some typo). This one work
I'll update once I get it apart and see what I have.
Old Apr 11, 2011 | 06:20 PM
jbradhill's Avatar
Engine: 383 SBC
Axle/Gears: 3.75 LS
Well, I got the gauge cluster out. and sure enough one of the wire plugs was not connected to the cluster. I plugged it back in and whala! ... Most everything worked. The termostat is still sickly. It was moving up to temp and then instantly dropped all the way down (cold). I then played around with the temp sensor and it came back to where it should be and then dropped cold again.... So I guess I don't know for sure if it is the guage or the sensor (I am awful with electricity)
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
355sbcTPI
Aug 19, 2015 04:38 PM
tnrednneck
Aug 13, 2015 08:57 AM
3rdgenparts
Aug 8, 2015 07:09 PM
