shifter swap
Old Apr 19, 2011 | 11:23 PM
Malachi85's Avatar
Car: 1985 Trans Am
Engine: 1978 5.7L 350 V8
Transmission: 700 R4
Axle/Gears: 10 bolt with 3.73 gears
shifter swap
does anyone know for sure in a stock automatic shifter from an 88 iroc will work in an 85 firebird. if so how. id doesnt seem to bolt up right. had a five speed in it.
Old Apr 20, 2011 | 02:13 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: shifter swap
If you had a 5-speed and are now going with auto, there is no way the automatic shifter will bolt right in. There is a hole where the mounts should be. Get the bracket off of the automatic car by drilling the spot welds or something and weld/bolt it into yours. It won't be that straight-forward but you'll get the idea.
BewleyBizzIROC
Feb 3, 2020 09:52 AM
camaro11j
Sep 19, 2018 08:49 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
rh76camaro
Exterior Parts for Sale
Aug 29, 2015 06:55 AM
NBrehm
Aug 25, 2015 11:49 PM
