Redying interior plastics
Old Jun 12, 2011 | 12:37 AM
SuperHawk996xx's Avatar
Car: 1986 Pontiac Trans Am
Engine: 350 cid bore too much to list.
Transmission: 700-R4
Ok, I was wondering does anyone have any advice on dyeing interior plastics? Mine are faded pretty bad and I want to do something about it. Any suggestions?
Old Jun 12, 2011 | 07:06 AM
hodder's Avatar
Car: 83 z/28
Engine: 305 4 barrel
Re: Redying interior plastics
try this thread https://www.thirdgen.org/forums/inte...ior-paint.html
Old Jun 15, 2011 | 07:33 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
I'm just finishing mine up and having great luck with excellent results. It may be overkill, but doesn't really take long and I like doing things right the first time, so I first cleaned the pieces with dish soap and warm water (if really dirty, you can use 'greased lightning' or 'simple green' cleaners). Next, I used SEM plastic prep spray and wiped it down - per instructions and finally, I used SEM interior vinyl, carpet etc. flexible spray paint. It's made specifically for this application and is carried in your better auto body supply stores. In Mass, I paid 13 bucks a can and you'll need at least 2 for the black pieces. I'll post pics later this month, but for now, I'm very happy with the results of the SEM. Advice; don't skimp on the prep work!
http://semproducts.com/Catalog.asp?prod=190
Old Jun 15, 2011 | 07:59 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
The SEM Is amazing! After cleaning really well, get some oderless mineral Spirits from home depot. Whip down really well, it opens trhe pores of plastic priming for paint. If you know how to paint you will be amazed at this paint. Good luck!
gta892000
Aug 11, 2019 11:16 AM
Numbah-1
Sep 12, 2015 08:57 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
scottmoyer
Sep 7, 2015 07:06 PM
90formulaVortec
Sep 7, 2015 06:54 PM
