lower door seals
Subscribe
Jun 12, 2011 | 07:09 PM
Hi every one I have a low mile (31,000) 1987 5.7 Iroc. I see these NOS lower door seal on ebay. I'm looking at the lower part of mt doors at the hull weatherstripping and don't see anything else. Did All camaros come with this seal? Can you see the seal with the door panel on? Thanks for any help. RObin Bailer Destin,Fl
Reply 0
Jun 12, 2011 | 07:13 PM
Re: lower door seals
the ones that go around the entire length of the bottom of the door? everyone has them!!
Reply 0
Jun 12, 2011 | 08:12 PM
I guess I'm still confused. Their is the door hull weather seal the one that goes from the rear of the side window down the door under the door then up to the front of the side window all one piece of weatherstrip. Is there another one (it does look different on the pics of them) that is JUST on the under side of the door?
Reply 0
Jun 12, 2011 | 08:13 PM
thats all one peice as you described it and all cars had it
Reply 0
Jun 12, 2011 | 08:45 PM
There's a second seal underneath the door on some cars. Check posts 2 and 3 in the link to follow:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Reply 0
Jun 12, 2011 | 08:51 PM
Quote: There's a second seal underneath the door on some cars. Check posts 2 and 3 in the link to follow:
JamesC
that big rubber flap thing? it was only on the later year cars
Reply 0
Jun 13, 2011 | 06:10 AM
Quote: that big rubber flap thing? it was only on the later year cars
My Parts and Illustration Cat. shows it available 82-91 (SEALING STRIP, BTM AUX 10125220).
JamesC
Reply 0
Jun 13, 2011 | 07:20 AM
Thank you everyone. I have ordered a NOS set to put on my '87. It didn't come from the factory with them but I am sure they will fit with no problems.
Reply 0
Jun 17, 2011 | 03:13 AM
Jamesc, do you have a close up pic of the lower door seal installed? I just received mine and not sure what way they should face. Does the smooth side go towards the interior of the car when the door is closed or the side with the ridges? Thanks
Reply 0
Jun 17, 2011 | 07:02 AM
Quote: Jamesc, do you have a close up pic of the lower door seal installed? I just received mine and not sure what way they should face. Does the smooth side go towards the interior of the car when the door is closed or the side with the ridges? Thanks
The smooth side goes against the door frame; the ridged side toward the door panel.
JamesC
Reply 0
Jun 25, 2011 | 07:31 AM
Thanks JamesC, I got them installed! I don't think they really do anything as far as wind noise, but there on..
Reply 0
Subscribe
