Seat track covers
Old Jun 13, 2011 | 05:08 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Seat track covers
I have a whole box of the things. My car didn't have any when I bought it. As a result, I have no idea which covers go where. I'm looking for a pic of the set that is set out as would be installed on the seats so I know which goes where. No power seats, though. Anyone have any pics?
Also, once I get a full set out of the box, the rest will be up for grabs . There's several of each in there except for one or 2, and there are some in there that may not be from an F-body.
Old Jun 20, 2011 | 01:39 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: Seat track covers
If you look at the underside they have part #`s on them.For the rears passengers seat uses last # 20 on right and 21 on left,drivers side uses last # 22 on right and 23 on left.
Old Jun 20, 2011 | 05:03 PM
Engine: 2.7L V6
Axle/Gears: 4.41
And the fronts?
Old Jun 20, 2011 | 07:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
There were no track covers on the rears, since the rears have no tracks only fronts have track covers.
Old Jun 20, 2011 | 07:47 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
my rear tracks have covers
Old Jun 20, 2011 | 07:49 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Thanks for being SO helpful... I don't think I need to worry about this with no rear seats or belts .
I think I meant the rears of the seat tracks, and of course the fronts...
Old Jun 20, 2011 | 07:50 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
He means the rear of the tracks.
Old Jun 20, 2011 | 07:53 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Did the fronts of the seat tracks even have covers? I know the power seat tracks had a one-piece cover (seen those around here and there here and on eBay).
Old Jun 20, 2011 | 07:55 PM
chevydrvr's Avatar
In my car, both seats have covers on all 4 corners. The passenger front ones are the smaller more shallow pieces. Sorry, I don't have pics.
Old Jun 21, 2011 | 06:41 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Went through the box... Have 3 of one, five of another, and several of yet another. No #23 (assuming driver's outer rear, near front seat belt floor retractor?).
Also have a whole load of #20206216, shallow, and a few 20206219. And a pair each of 20020723 and either 24 or 22 (each side, I'm assuming), and a 20605183. Pretty sure the last couple aren't F-body, but maybe the 216 and 219? IDK, .
Old Jun 21, 2011 | 09:16 PM
Engine: L31 350
ill get you a picture, are they the same from a bird to a maro?
Old Jun 21, 2011 | 09:22 PM
Engine: 2.7L V6
Axle/Gears: 4.41
As far as I know. They are pretty much the same seats, and the tracks should be identical...
Either pics or part numbers would help.
Old Jun 21, 2011 | 09:28 PM
Engine: L31 350
ill get them in the morning for you
Old Jun 22, 2011 | 09:07 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Same here. Both seats had covers on all corners. Front cover for the tracks appeared identical for both seats and for left and right if I remember correctly. A small cover that attaches using a single screw on the top.
The rears are somewhat more complicated depending on power or no power for passenger or driver.
For the rear I'd go by the description my82roc gave.
Old Jun 22, 2011 | 05:48 PM
Car: 1992 RS
Engine: Carbed 350
Here's pics: http://cgi.ebay.com/ebaymotors/82-92...Q5fAccessories
The larger ones for the front of the track, the smaller one for the rear of the track.
I finally figured out what folks meant by rear tracks, and I feel like an idiot - sorry!
Old Jun 22, 2011 | 06:04 PM
chevydrvr's Avatar
It's the other way around in my car. Those 4 you poasted are for the passenger seat. THe smaller ones go on the front. It's more obvious when you look at the track.
Old Jun 22, 2011 | 06:16 PM
Engine: 2.7L V6
Axle/Gears: 4.41
, but I already figured this out in my Parts Wanted thread... I have all the covers except the #23 described above. If anyone needs any, I have a couple extra of each except the #23 (which I have none of), and a whole bunch of the flat 20206218 covers for the in the front of the tracks.
morrow
Jan 13, 2024 12:29 PM
Amillionoh7
Sep 5, 2015 11:44 PM
SG91camaro
Sep 5, 2015 10:27 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
