Recovering Dash
Old Jun 24, 2011 | 05:09 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Recovering Dash
I am attempting to repair my junk Camaro dash. I am going to go and get some stretch vinyl material and permatex headliner adhesive. My question is for those that have done this before. What did you do regarding the speaker grilles and defrost area? I was thinking about using some wire mesh in the area, but am unsure.... Not much on here regarding this....
Old Jun 24, 2011 | 10:50 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Recovering Dash
I was going to recover mine, I just cut the grills out since they were cracked, but I decided I didn't want to go through the trouble, esp since the damn thing is heavy, I'm just going to get a one piece fiberglass dash(not just a dashpad mind you) that weighs like 1/3 what the stock pad does, but I'm also a weight ****, and my cracks on my pad were furled upwards, I don't think I could've gotten everything flush, it just cracked more when I tried grinding them down too.
Old Jun 26, 2011 | 10:23 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
Re: Recovering Dash
how did it turn out?
Just curious.
Old Jun 28, 2011 | 09:25 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: Recovering Dash
I've seen several people on here try to recover their dash, it never looks good. Just put one of the carpeted dash covers over it until you can get an OER replacement.
Old Jun 28, 2011 | 11:20 AM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
Re: Recovering Dash
I'm in the middle of doing a new dash for my car. I got another dash pad from junk yard. I stripped everything off it, and fiber glasssed it. Put new foam and covering it with rolled and pleated black to match rest of interior. I'm going old school look.I put black pipping with vinyl attached around speakers and defrost front vent. The vinyl attached to pipping dropped down along side of grill so would lay flat and gluded it in place. Same thing with defrost vent. I closed the small defrost vents. I drilled holes through speaker grills attachment points (4) put in long screws counter sunk screw heads bondo on the head and repainted the grills black. Made spacers from plastic pipe to raise the grills to meet flush with dash pad. I still have a little more work to do where it wraps over the front and tucks under. At this point not happy with how it is rolling over front. I may have to make the front thicker to get it to smooth out.
I made a cardboard templet of dash had a shop sew me the rolled and pleated vinyl, I'm doing everything myself.
Old Jun 28, 2011 | 07:47 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: Recovering Dash
Would love to see pics....
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
