ez cool insulation
Old Jul 12, 2011 | 10:32 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
ez cool insulation
does anyone have any experience with ez cool insulation? its cheap.heres a link. <http://www.lobucrod.com/>
Old Jul 13, 2011 | 04:39 AM
*84TA's Avatar
Car: 84 Trans Am
Re: ez cool insulation
I installed it in my car. Easy to do. Just cut it to fit and hold on place with some 3M spray. There is definitely a noticeable difference in the amount of heat I had coming off of the trans tunnel and through the shifter boot. There is a link on the site to a guy who did a test on its insulation properties. It will definitely will help keep the cabin cooler. As for the sound deadening quality I can not say, because I installed a much quieter exhaust on my car during the restoration. I figured for the price you cant go wrong. If you don't like it its a only a days worth of work to take out and put in dynamat or similar.
Post #19 in the following thread has pictures of my install. https://www.thirdgen.org/forums/inte...deadening.html
Post your results when done with the install, if you go this direction.
Old Jul 13, 2011 | 04:30 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
thanks alot man
Old Mar 7, 2012 | 02:44 PM
Swigbeast's Avatar
Hi, I've been doing some research on the EZ cool and thought I'd jump in here and ask a couple questions before I go and buy some.
Im in the process of putting in a new interior in my car, so I figured, why not go floor up and just go all out.
I will be going to Lowes and buying the Peel and Seal sound deadener and rolling that on, but I also would like to add this EZ Cool insulation. I will be getting my AC fixed for the first time in 5 years and having the cabin as cool as possible would be great.
I dont see a problem wit just putting the ez cool over the matting, but maybe I'm looking at it wrong. Does that sound like a solid plan? Also, I'm looking to reduce road noise, does EZ cool help in that area any?
Any response would be much appreciated. This is my last step. I cant wait to tear my car to pieces!
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
gta_knight
Sep 23, 2015 04:59 PM
