L.E.D. Dome Light disapointment
Old Aug 1, 2011 | 11:16 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I just recieved my LED Dome Light from SuperBriteLEDs. I must say, Im quite disapointed to find out that the light is not too bright. It is bright without the Dome Light Cover lens, but with the lens on, it doesnt cut the cheese. The type I bought is model number:
RL4410-xHP9: Rigid Loop Festoon bulb-RL4410-CWHP9: Cool White
( http://www.superbrightleds.com/cgi-b...L4410-xHP9.htm# )
Old Aug 1, 2011 | 11:17 PM
Re: LED Dome Light
Which one is the brightest white available?
Old Aug 2, 2011 | 07:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: L.E.D. Dome Light disapointment
You want bright? Try this:
https://www.thirdgen.org/forums/inte...-overhead.html
Be sure to note post #5.
JamesC
Old Aug 2, 2011 | 02:35 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I did the same LED panel as shown in above link (well, not from Superbright, but cheap China model) and it's blinding!
Old Aug 2, 2011 | 04:34 PM
Do you remember the model number or the name of the ebay seller?
Old Aug 2, 2011 | 05:41 PM
SinCityLocal's Avatar
Car: 1990 Mazda B2600i Cab Plus L98 Swap
Engine: 5.7 TPI, LT1 cam, 24 lb. Inj.
Transmission: BowTie Overdrives Level 2 700R4
Axle/Gears: 3.909
I'm waiting on one of these right now.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Old Aug 2, 2011 | 05:56 PM
Car: 1992 RS
Engine: Carbed 350
It was over a year ago, so ebay history no longer there. But it was one just like this (they are all about the same): http://cgi.ebay.com/ebaymotors/Car-I...Q5fAccessories
Old Aug 2, 2011 | 06:18 PM
DAAAAMMMNNN!!!! Dirt Cheap!!! Ima buy it right now!!!! Thanks camaronewbie. Ohh. One more question. How bright is the interior after you installed your panel?
Old Aug 2, 2011 | 06:24 PM
Car: 1992 RS
Engine: Carbed 350
Bright enough to read by - all night long, in front seat or back seat (or even the trunk) - it's blindingly bright!
BTW - I also replaced my truck light with a 18 LED panel (18 LED panel needed since trunk light "facing" is much smaller than the dome light area).
Old Aug 2, 2011 | 06:26 PM
Nice. But certainly it is brighter than the incandescent bulb right?
Old Aug 2, 2011 | 06:28 PM
I just dont wanna get burned as I just did by SuperBriteLED.com. I got a LED for the dome light but it aint that bright. Also in their vehicle buld identifier, it claims that a bulb for the map light in the rearview mirror is of a certain type. Well that damb type ended up being WAY too bulky and it dont fit. So I may just use them for the trunk and the kickpanel lights.
Old Aug 2, 2011 | 06:32 PM
Car: 1992 RS
Engine: Carbed 350
At those China prices, all you have to lose really is time. It takes about 2 weeks to get them (slow boat, customs, etc.)
Mine is literally about 50 times brighter than the stock incandescent bulb ever was.
Old Aug 2, 2011 | 06:36 PM
Nuff said. Thank you camaronewbie.
Old Aug 6, 2011 | 10:13 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
totally buying one of these
Old Sep 21, 2011 | 06:07 PM
Axle/Gears: 3.909
Got these a few weeks ago. Almost too bright!
Old Sep 21, 2011 | 10:09 PM
This is what I got, cheaper too.
http://cgi.ebay.com/ebaymotors/ws/eB...84.m1439.l2649
Old Sep 22, 2011 | 04:55 PM
one92rs's Avatar
Car: SOLD!!!!!
just ordered one myself.
Old Sep 22, 2011 | 06:00 PM
Cool. Ill try to remember to take a picture of how I installed mine. All I did was use the Festoom spring loaded and pushed it all the way up and then put the LED board in the spot where the light bulb goes. The board is just wide enough to fit in the holder. Im very very pleased with the results.
Old Sep 22, 2011 | 06:22 PM
JamesC's Avatar
The link I provide above shows the install.
JamesC
Old Sep 22, 2011 | 07:19 PM
Yup. The link that JamesC is another method. Its is a more permanent solution, but the way i did mine, it is still plug and play. In other words, you can still switch to a bulb if you chose to switch.
383cam
Sep 9, 2015 06:01 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
