A-pillar trim for T-tops.
Old Aug 2, 2011 | 04:02 PM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
The A-pillar trim for t-tops... Does anyone know what the difference is? Checking parts numbers, I see 2 different parts number for an 82-92 model. The first type seems to cover everything from 82-part of 91. The other seems to cover the rest of 91 to 92. I can't imagine what they might have changed, but I do not want to buy an incorrect pillar piece just in case it's something that can't be worked with.
Old Aug 2, 2011 | 04:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: A-pillar trim for T-tops.
I don't know - I know the T-tops had a larger pin in the later years (actually, the pin itself wasa the same, but later years had a plastic sleeve over the pin that made it larger diameter), so it might have to do with the hole in the plastic A-pillar trim for the T-top pin. But othert han that theory, I wouldn't have a clue, since the pin-style T-tops are all interchangeable.
Old Aug 2, 2011 | 04:10 PM
Elthesh's Avatar
Hmm, well, my vin falls far under what the listed cut off is for the 82-91 and my t-tops use the fat pin style. I gave mine a once over and looked at some pillar trim up for sale and the ones that show the hole for the pin, it doesn't look any different than mine. So, I can't imagine what could be different about the pillar trim made for the later 91 and 92 cars.
Old Aug 7, 2011 | 12:43 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Originally Posted by camaronewbie
I don't know - I know the T-tops had a larger pin in the later years (actually, the pin itself was the same, but later years had a plastic sleeve over the pin that made it larger diameter), so it might have to do with the hole in the plastic A-pillar trim for the T-top pin. But other han that theory, I wouldn't have a clue, since the pin-style T-tops are all interchangeable.
My 86 had the OEM T-Tops (just a small pin). But then I acquired a set of later year T-Top glass that have the large pin. Get this, that large pin is actually a spring loaded sleeve with a small pin that sticks out of the large sleeve. My pillar has the small hole. So when I latch the tops, the whole sleeve sliders out until it makes contact with the small hole in the pillar and then the small pin penetrates through (thats what she said!) into the pillar hole for a nice snug fit.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
