replace dash pad 92 Camaro
Old Aug 9, 2011 | 06:40 PM
polara1965's Avatar
ok so i purchased a 1990 dashpad mint condition, how do i remove the old one? anyone have instructions or a site?
Old Aug 9, 2011 | 07:02 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: replace dash pad 92 Camaro
IIRC, four screws in the defrost area (don't lose them down the ducts) and perhaps a half dozen under the front lip. Take a peek.
JamesC
Old Aug 10, 2011 | 12:28 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
JamesC
very easy job to do
Old Aug 13, 2011 | 04:49 AM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
Note: Be VERY cautious while putting it back on when it comes times to tighten the screws. Don't tighten them like you would normally think would be considered tight.. Basically just enough to make contact with the pad and VERY slightly tighten to take up any slack/movement. Over time, especially when the pad flexes with the heat, the overly tighten screw will cause the pad to eventually give way to a single crack. Once that happens, it will continue to crack.
One large pothole and that hairline crack can turn to one LONG slice!
Be very careful with the screws where the windshield meet. THOSE are the buggers that crack REAL EASY!
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Vintageracer
Aug 11, 2015 08:13 PM
