Gear Selector looks wrong
Old Aug 10, 2011 | 06:08 AM
Krishan's Avatar
Car: 1991 Z28 Camaro
Engine: 5.0 305 TPI
Transmission: 4-spd Auto
I know that the car was in a front end collision, but how do I fix this?
It's in Drive but cosmetically its in neutral.
Old Aug 10, 2011 | 07:24 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Gear Selector looks wrong
You have to remove the cover( four torque screws & shift ****)) and adjust the plastic indicator strip to the correct position.
Old Aug 16, 2011 | 08:10 PM
Krishan's Avatar
Engine: 5.0 305 TPI
how do you remove the shift ****?
Old Aug 16, 2011 | 08:25 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
On the back of the shift **** (closest to the radio) you will see a small pin either square or oval shaped flush against the shifter ****. The best tool to pop it out is a very small flat screwdriver (like a jewelers). Once the pin is out, grasp the shift **** and lift straight up. To re-install, slide it back on and insert the pin again. You can just use good finger pressure to seat it.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
TheTraut88
Sep 7, 2015 05:22 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
dhonda200
Aug 11, 2015 11:50 PM
