AC trouble
Old Aug 19, 2011 | 05:01 PM
SpeeProd's Avatar
AC trouble
So i installed a new AC compressor and drier on my 87 IROC, but the air only comes out of the vents on top of the dash by the windsheild... I live in a very hot climate this time of year and i want to be able to count on my AC, anyone know how to fix this so the air flows through ALL the vents?
Old Aug 19, 2011 | 07:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: AC trouble
You have a vacuum leak. The 'doors' that redirect the air flow are controlled by vacuum - and the 'no vacuum' default setting is defrost vents.
Old Aug 19, 2011 | 09:12 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: AC trouble
I had the same issue. Easier way to check them is to pull the heater/ac controls out from the console and check each line there. If you turn the car on and then the air you can try and listen for an air leak. If you dont hear anything there, your going to have to trace the lines out to each source which will be a major PITA.
Old Aug 19, 2011 | 10:34 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: AC trouble
Sometimes there may be a leak, but it will just stop by itself. Sometimes. I know mine does that every morning. I start it, ad set it to the defrost, and it hisses like crazy. 5 minutes later, it just stops and works fine. Weird.
Old Aug 22, 2011 | 06:15 PM
SpeeProd's Avatar
Re: AC trouble
Thanks guys, ill be sure to check it out.
Old Aug 22, 2011 | 06:16 PM
SpeeProd's Avatar
Re: AC trouble
Where is the console exactly?
Old Aug 22, 2011 | 06:37 PM
Re: AC trouble
Right above the radio, the controls there. Vaccum lines go into the back of it to tell the air where to go. Unscrew the bezel and there should be a few bolts holding the controls in (10mm i think). Take those out and the control should slide forward some.
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
eduardosac
Sep 16, 2015 02:18 PM
