need a little help on my dash repair idea
Old Sep 8, 2011 | 06:41 PM
justcallmeclassy's Avatar
Car: 1992 Camaro RS Z03 T-Top
Engine: L98 with TBI
Axle/Gears: 2.73...
So my dash, like so many others, is the victim of the sun. Huge grand canyon sized cracks run up it vertically. My initial idea was to cover it for awhile, but I hate the way those dash pads look. I reapolstered my headliner and door panels myself with a black vinyl and it looks amazing, so I got the bright idea to try that on my dash... not so great... but I was thinking what if I used some sort of filler in the cracks, and sprayed the whole thing with bed liner? A little googling led me to where a guy had done this with an old porsche or something, and it looked beautiful. Only problem is I have no idea what to use for filler... like not even the slightest idea so any suggestions? Or if anybodys tried this before care to share your results?
Old Sep 8, 2011 | 06:53 PM
89RSRedConv's Avatar
Re: need a little help on my dash repair idea
Check it
http://gtam.silvahalo.com/dashrepair/
No info on how it held up over time, i thought a member (from The Great Sate of Texas) did it and say after it did nto hold up, but I could be wrong.
Old Sep 8, 2011 | 07:15 PM
Axle/Gears: 2.73...
That is exactly what I was looking for thank you very much. Any idea of what that epoxy stuff was called?
Old Sep 8, 2011 | 07:53 PM
FooFighters92's Avatar
Car: 1992 Firebird & 2009 Nissan 370Z
Engine: 305 TBI
Transmission: W.C. T5
Axle/Gears: 4th Gen Posi, Disc Break/3.42
If I were you I'd just check a junk yard, Craiglist, or eBay...
Check a junk yard first though. Mine was like yours...found an absolutely perfect one at a junkyard for 20$
Old Sep 8, 2011 | 08:01 PM
Axle/Gears: 2.73...
I've already checked everywhere, I haven't been able to find a single junkyard within 150the miles that has a single third gen, except an f body specific one and they charge almost as much as brand new
Old Sep 8, 2011 | 08:20 PM
FooFighters while I don't want to sound like a jerk ... I don't think I am going to find a solid dash on line cheap and the pick and pulls around me I am lucky to find a Camaro let alone a twenty year old mint dash pad ... respectfully
Mine is not that bad and I may still go the glue and spray route.
Old Sep 8, 2011 | 08:24 PM
The Glue
Fiberglass Evercoat 885 Medium Urethane Adhesive 250ml MAXIM™ Medium Urethane Adhesive is a hybrid urethane that provides superior adhesion and flexibility for plastic repair needs. It can be used for multiple applications including bumper tabs, moldings, emblems, brackets and small plastic parts. The best choice when a “super fast” cure time is necessary. Sand and drill in 5 minutes.
OHIO you are in the rust belt the same as me junkyard cars don't survive the winter here. LOL
Old Sep 8, 2011 | 08:29 PM
Engine: 305 TBI
Doesn't hurt to check. I just skimmed eBay and saw a couple that were pretty expensive, but hey you could get lucky. I realize I struck gold when I got mine. And it was weird, I didn't bring any tools and there wasn't a single screw holding this dash in. Besides one little screw that I finger twisted out.
There's gotta be at least 3 or 4 Camaro/Firebird parts cars on your local Craigslist. Just gotta keep checking
Old Sep 8, 2011 | 08:35 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
hit a J/Y , craigs list , ebay , all good ideas . ( i put one away with a crack for future use ) i have a 99.9% mint pad on my car . but , someday there will be no more stock ones for sale . any thoughts/methods to re-furbish original ones is great . good luck .
Old Sep 8, 2011 | 08:36 PM
/sigh
Yea I just checked the eBay there is a solid one going for 150 with ship some time left and lots of bidders. I get frustrated when I hear "just go to the pick and pull and get one" if your in the South or California, sure, not up here in the lets crush and cash out mentality area.
Old Sep 8, 2011 | 09:54 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
have you thought of fiberglassing it if so I made a thread about how to do this it is title "has anyone done this or seen this done"
Old Sep 9, 2011 | 05:03 PM
Ok here's the thread
https://www.thirdgen.org/forums/inte...seen-done.html
BTW MSRed91Camaro F*N* Fantastic Job
Old Sep 9, 2011 | 05:14 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I wanted to redo my dashboard but its a bit too cracked. I think its beyond repair.
Old Sep 9, 2011 | 05:34 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I was the one from Texas that did the fix. I shouldn't have tried it on a dash that was so far homer. Maybe if the was a minor crack and it didn't need much sanding it would have been better
Old Sep 9, 2011 | 05:38 PM
I found another site that explains how to do a dashboard repair....
Old Sep 9, 2011 | 10:31 PM
Engine: 383 stroker
BTW MSRed91Camaro F*N* Fantastic Job[/QUOTE]
Old Sep 9, 2011 | 10:32 PM
Engine: 383 stroker
The one I fiberglassed was terrible it had cracks about 1/4 an inch wide in some points
Old Sep 9, 2011 | 11:47 PM
Damb. I bet you where happy as hell to fix it. But i dont have the talent nor the place to do a fiberglass job. I live in an apartment complex. Ill take pictures to show you my dash. It think it is horrible. Some cracks on mine are more than 1/4".
Old Sep 9, 2011 | 11:53 PM
58mark's Avatar
https://www.thirdgen.org/forums/inte...highlight=dash
Old Sep 18, 2011 | 08:19 PM
Im gonna upload my dashboard in a bit to show how severe mine is.
Jorlain
Aug 24, 2022 05:11 PM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
Jk_Under
Sep 2, 2015 10:59 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
