adding power windos and locks
Old Oct 5, 2011 | 07:55 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
ok i have a 92 rs camaro. but my buddy is just got a 84 camaro z28 and i was going to add all the poer stuff to my car. what do you think
Old Oct 5, 2011 | 10:50 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: adding power windos and locks
swapping all the stuff can be done . it's a pretty big chore , very labor intensive . a much easier way is to ck. out "SPAL" for their conversion kits . my present car has a kit from them . works good , looks almost like stock . they also have very good instructions . whatever you do , good luck .
Old Oct 6, 2011 | 01:12 AM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
Re: adding power windows and locks
I did the conversion on my 84 TA, windows,locks and mirrors. It is really not that bad of a job to do. The two hardest things for me was getting the windows lined up( to close right) and cutting the holes in the console for switches. It took me two days.
Old Oct 6, 2011 | 05:14 AM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I know this might sound stupid, but tis there any way to have power windows, but still have the crank handle on there that spins? I hate not having power windows, but I want it to look as close to original as possible. I've seen a few of these kits, and they don't seem to bad!
Old Oct 6, 2011 | 06:38 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I would think that the easiest way would be to find a junkyard car that has everything you want and swap the parts and wiring over.
chevydrvr: Are you thinking hidden switches? Having the crank handles spinning by themselves would be hilarious. Don't think it would work, but i'd like to see it. And it might be useful, too - if you want to wake up a sleeping passenger, you can whack him in the leg with the crank handle with the push of a button.
Old Oct 6, 2011 | 06:53 AM
chevydrvr's Avatar
Yeah,exactly. I was thinking of hiding the switches. Maybe ill find a way to just attach the handles to the door panel??
Old Oct 6, 2011 | 08:52 AM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
I got everything off ebay, even the wiring. I bought new motors, switches and lock actuators (did not want to use old ones). You have to change regulators to power setup, no crank handle on them. I did get the new switches from classic industries.
With the power locks you can put a aftermarket remote door opener on the setup. The one I bought cost 29.00.
It cost me more for L&R power mirrors than the power window and lock setup.
I also ran a seperate power setup. I installed a relay and fuse near the battery and ran the power line into the car. The reason for the relay is because I wanted to have the windows work only when the car is running. The locks I ran from constant power from fuse box, you need that for the remote locks to work.
Old Oct 15, 2011 | 01:05 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
They have these kits! specifically for older cars like bel airs where you puth the crank handle down or up a bit to move the window up or down. the same company sells smoke screen kits and flame thrower kits, Im pretty damn sure its auto-loc or something like that.
Old Oct 16, 2011 | 07:15 AM
chevydrvr's Avatar
I looked up autoloc, and they do have window crank switches! They would be perfect, as long as I could somehow wire in a third switch for the driver to operate the passenger window. Those switches are $100 each though. Kinda steep for me.
Old Oct 16, 2011 | 08:26 AM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
Why don't get a setup like this.
http://cgi.ebay.com/82-92-Camaro-Fir...sories&vxp=mtr
This is what I did makes life simple, its like plug and play.
Old Oct 16, 2011 | 08:48 PM
Flat Black Camaro's Avatar
Car: 89' IROC Camaro
Engine: 350 HO
Transmission: TH350 Turbo
Axle/Gears: Moser / 3.73
I work for a hotrod shop and when we add power windows to older cars we always buy this kit from AutoLoc for powered windows. its pretty much a switch behind your window crank, the only fall back is when people get in and try and roll your windows down ive seen people twist the arms off. But if your interested check it out
http://www.autoloc.com/catalog/OEM-W...Crank-Switches
Old Oct 30, 2011 | 12:05 PM
cha_chard's Avatar
Car: 89 Camaro RS
Engine: 2.8L V6 MPFI
Transmission: 5Speed
im thinking about doing pl but i have no idea about the wiring i have never wired anything -_-
Old Sep 23, 2012 | 10:36 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Sorry for diggin this thread up, but I don't want to add yet another "adding power windows" thread.
For those that have added kits or oem, what do you do for the hole in the door panel where the old window crank was? Are you getting an OEM door panel one as well? In my search for a new car, I'm now realizing that there were lots of different styles of interior door panels, so that doesn't seem likely.
Old Sep 23, 2012 | 10:46 PM
JLCustomizing's Avatar
Car: 1984 Trans Am
Engine: 5.7 Liter V8
Transmission: Auto 700R4
Axle/Gears: Stock
Find the oem circle plugs for them. I have two sets from an 81 firebird, different color bird but fit right into the hole where the handle was. You can find them for like 15 bucks.
Old Sep 24, 2012 | 07:37 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Ok, thanks. I didn't realize the stock p/w cars had a plug; figured they'd have a hole-less door panel.
Old Sep 24, 2012 | 08:20 PM
toomany's Avatar
I think some of the earlier cars had plugs in the panels. My 82 does. My 88 did not. I went the other way on my 82, swapped over to manual stuff. Couldn't stand the slow windows, plus it's a drag car and weight=ET. I had an 83 that I converted to power (windows, locks, mirrors, pull down hatch). Was plug and play with factory parts.
Old Sep 25, 2012 | 06:54 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
If the door panel is carpeted, it's really easy to make a plug.the carpet fibers make it very hard to see if you fit it right. You can use a piece from a bad panel or one of your carpet edges that are unseen under the trim.
BRoss99
Aug 10, 2025 05:08 PM
colton_carlson
Mar 8, 2019 12:21 PM
mantaguy
Sep 1, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
