Water Leaking into Car...
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Water is leaking into my Right Passanger footwell... No clue?
Usually happends when I wash the car, noticed last year when it rained... Finally got around to moving the carpet for inspection... Thoughts/Ideas??
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Water Leaking into Car...
the drain in the cowl area, under the wipers, can rot out and leak, and the firewall below the A/C equipment can rot too. If its not coolant, that could be it.
come to think of it, i had a bad door seal on the PS side and that was leaking into the car too. Something to check
Car: 1989 camaro RS
Engine: RAMJET 350
Transmission: RAPTOR 700-R4
mine is doing the same thing it was aggravating me. i found no traces of where it could come from i stripped my dash off and monitored it. i found mine was following the ecm harness and dripping down. never seen anything like that.
I had water on the drivers side floor years ago that was caused by a loose grommet on the firewall. When it would rain the water would run down the firewall, attach itself to a cable and pour through the opening. A little bit of putty around the hole put an end to it.
Car: 1986 Pontiac Trans Am
Engine: LG4 305/V8
had the same thing happen to me about 2 weeks ago when it rained for about 4 days straight...i had a puddle in the passengers side...mine was a simple fix...the weatherstrip (the triangular one at the front of the window) was slightly lifted up, i was able to actually see some light through the hole. All i did was push it back down and problem fixed.
Heater Core is a Definate No..
I would like to see some pictures of possible area's to check, So I know exactly where to look. Thanks.
Car: 1987 F-bird
Engine: 350 Vortec
Transmission: Manual
Check this area (painted red) above heater core hoses, i've found yesterday water inside my car too!
if you have the same problem, just remove plastic grill under washers, clean as much as you can and put new seal there.
In my car there were two water traces, leaking straight to holes in firewall where the heater core connects to hoses.
I poured some water into the area covered by the Plastic Grill by the Window Wipers. Poured two cups before I realized the garage was not a good place for this. I noticed the some chunks of Glue? or something on the floor boards has started to come loose? big chunks
Jesus, I posted this thread last year around the same time, and have still not managed to fix this leak...
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
I have found many water leaks in cars by removing trim panels so that the underside of the dashboard can be visualized. You may want to remove the kick panel. Park the car under a lawn sprinkler, and get inside, and have someone turn on the sprinkler. You may have to put your head under the dash with a flashlight, but usually you can spot the leak. It may be something very simple. Good Luck!
Charles
Charles
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
My car appeared to be rust free. when it would rain the pas. floor board would have standing water. I 1st I thought that the water was getting in where the engine harness passes through kick panel. but this is what I found to be the culprit. this is caused by the cowl drain getting leaves in it, you can not see the drain unless you remove the inner fender.
Although I do believe that if I remove the inner fender I will find that the cowl drain is plugged. It's dripping from where the harness enters into the vehicle. My poor baby.....
What is the seal for the ECM Harness?
