Hatch pulldown motor problems
Old Oct 22, 2011 | 04:10 PM
scott_kelley's Avatar
I have replaced the wiring harness and the pulldown motor on my 91 camaro. It started giving me problems a few years ago and I troubleshot it down to first the harness and then also the motor. After these components where replaced I was testing it out before pullingout of the garage and noticed that it would only complete one cycle of down and up before not moving again. The switches on the relay trip at the down and up position, and the only way to get it to operate is if I take it all apart including removing the motor and reassembling it. Has anyone else experienced this problem or know how to fix it because I am stumped. Thanks
Old Oct 22, 2011 | 04:26 PM
grassyflats's Avatar
Re: Hatch pulldown motor problems
i fixed it buy replacing the whole unit via TopDownSolutions lol ... $300
Old Oct 22, 2011 | 05:37 PM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
i noticed this with mine, it would do the cycle 2 times max a day or even a week. My cultprit was found when i replaced the reverse switch located on top of the plastic gear. cured all the issues i was having.
Old Oct 26, 2011 | 11:11 AM
stahrman0612's Avatar
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
I started having problems with mine about 7 years ago. Didn't want the motor to go completely dead while closed. So I put the motor pulldown where I wanted it, disconnected electrical and have been using it like a regular hatch ever since. Opens and closes perfect!!
Old Oct 26, 2011 | 11:15 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
The big problem that people forget are the nylon slides & plastic gear. The motor & switch are not always the problem.
Old Oct 26, 2011 | 11:38 AM
Car: 1986 Trans-Am
Engine: 305 4 bbl
Axle/Gears: posi
Before I stopped using that feature, I would unlock it, it would go up.....then go right back down. So I had to time it just right and grab it or it would close again. Probably just out of adj.???? No worries anymore!!
Old Oct 26, 2011 | 12:09 PM
DJP87Z28's Avatar
How are your hatch struts???? they should pull the hatch up before the close function works.
Old Oct 26, 2011 | 01:14 PM
Car: 1986 Trans-Am
Engine: 305 4 bbl
Axle/Gears: posi
Shocks might have been shot?? Not sure if I replaced them before or after?? Not going to fool with that pulldown ever again though!!! Thought I'd throw in a pic of my baby!!
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
