Dynamat or Hush mat, cheaper?
Old Oct 26, 2011 | 12:09 AM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
So I just orderd my Dove grey carpet set from Ecklers camaro for my 89 IROC along with a new set of custom floor mats. I was going to order the floor kit Hush mat set they have but $250.00 just for insulation sounds a little steep to me. Anyone know of an alternative or other place where I can get it cheaper? I don't think the insulation should cost the same as the carpet.... just doesn't make sense! lol...
Old Oct 26, 2011 | 05:58 AM
82tarecaro's Avatar
Re: Dynamat or Hush mat, cheaper?
I think there is a spray on stuff called Lizard Skin.
Old Oct 26, 2011 | 06:01 AM
82tarecaro's Avatar
I just checked-the Lizard Skin kit is a couple of hundred bucks - not really much savings.
Old Oct 26, 2011 | 08:09 AM
stahrman0612's Avatar
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
If you have an Andersons nearby, they have Dynomat fairly cheap. They order most of their automotive accessories from a place called Wholesale House in Hicksville Oh that sells stuff really cheap to licensed vendors. They only charge about 20% more than wholesales's price. I did my whole hatch for sound......about $40 dollars.
Old Oct 26, 2011 | 08:35 AM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Now thats more like it! What type of business is Andersons? I'm not sure if we have one in Chattanooga, TN but I'll check. Also I'm going to hit some of these stereo installation places to see what I can find. But because I'm the type of person that does not cut corners I may just break down and buy the Hush mat kit from Ecklers. This IROC is getting nothing short of perfection when it comes to parts so if I go broke, well, at least its not on a woman.. lmao.. hope my girl doesn't read this...
On a second note, to those who have installed their own carpets. I've seen several different types of insulation. Classic industries has the factory stuff really cheap but I don't think it works that great. Opinions? Also I've seen just sound deadener then other types that are heat resistent as well. The Hush mat from Ecklers seems to be an all around good insulation, thus the reason its so pricey...
Old Oct 26, 2011 | 08:55 AM
Car: 1986 Trans-Am
Engine: 305 4 bbl
Axle/Gears: posi
It's kind of like a department store....they sell bakery, wine, furniture, auto...etc.
Old Oct 26, 2011 | 03:03 PM
inkedbass's Avatar
Google search Second Skin Audio
They make GREAT deadener and have heat resisting products too.
J
Old Oct 26, 2011 | 09:13 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
I bought this and I've been very happy with it. The only bad part is the installation; it's time consuming and you'll be sore afterward after all the contortioning you'll do if you attempt to cover every square inch like I did. I estimate that it took me at least 18 hours, but again, I used every last bit of that 100 foot roll which will do your entire car. 100 feet, shipped free, is what made me purchase it from this seller.
http://www.ebay.com/itm/100-80-Mil-R...item2a0dd6c737
Attached Thumbnails Dynamat or Hush mat, cheaper?-july-pics-242-half   Dynamat or Hush mat, cheaper?-july-pics-246-.
Old Oct 26, 2011 | 09:31 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I've read that hushmat is like an all in one solution.. Prevents rattles and vibrations, it is a thermal barrier, it isolates the interior from exterior noise like wind, exhaust, gears, fuel pump, road noise, etc.. and it is just easy to install, just peel, stick and roll.. Do all brands do the same thing? I've also read that it uses an odorless adhesive, unlike other brands that apparently use asphault lol!
Old Oct 26, 2011 | 10:23 PM
droptop91z's Avatar
Car: 1991 Camaro Z28 Convertible
Engine: 383 Tpi
I have used it all, HushMat, DynoMat , FatMat. Lizard Skin The best bang for your buck is the Fat Mat, No major difference in any of them, but the FatMat is def the cheapest. I ordered it straight from FatMat. www.fatmat.com
Old Oct 26, 2011 | 11:46 PM
inkedbass's Avatar
Some tips
1) Clean the surface for application THOROUGHLY. Sticking this stuff to a dirty surface is worthless.
2) Warm with a heat gun before application. This allows the rubber/butyl to melt and stick better to the metal.
3) Roll over it with a roller. Look for a wooden roller about 1" wide (second skin does sell these, I can rarely find them for sale elsewhere) to help apply the deadener evenly. Just remember its not just weight and thickness but the actual materials to block out sound.
J
Old Oct 26, 2011 | 11:48 PM
cookie21's Avatar
Car: 1992 RS
Engine: ZZ4
look up FATMAT on ebay, i just used it when doing my carpet and it was a piece of cake and i did the whole car for 100 bucks and that includes rollers and shipping. I then picked up a heat gun from harbor freight for 13 bucks and used that on it, worked great.
Old Oct 26, 2011 | 11:58 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
I want to do my car this winter but i heard the stuff they use for air-crafts is the best. My neighbor is restoring a 79 VW van, thats what he used. I need to get the website where he bought it. I will let you guys know once I do. He said it is the best!
Old Oct 27, 2011 | 12:00 AM
inkedbass's Avatar
I'll just say this.............I have 2 layers on my wife's truck and it quieted the noise from the outside TONS and made her rattles from my old stereo system go bye bye
J
Old Oct 27, 2011 | 03:14 AM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
That looks great in there! I may do my whole car as well, I'm wanting to install a good stereo system once the interior is complete so why not.
Old Oct 27, 2011 | 03:17 AM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Originally Posted by inkedbass
Some tips
J
Thanks, makes sense... I wouldn't have even thought about the roller
Old Oct 27, 2011 | 07:34 AM
Warpedsv's Avatar
Awesome I will be making my red interior completely black and def going to install the fat mat bulk kit cannot wait
Old Oct 27, 2011 | 12:54 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
You know,new carpet with mass backing would achieve the same results,don't you think that's a little bit of overkill.Well that's my thoughts anyway.
Old Oct 27, 2011 | 12:56 PM
Warpedsv's Avatar
good thinking did not think of that, appreciate the input does all new carpet come with the mass backing?
Old Oct 27, 2011 | 12:59 PM
mantaguy's Avatar
Engine: 5.0 EFI
No, it cost a little extra,but it all goes down at the same time.
Old Oct 27, 2011 | 01:01 PM
Warpedsv's Avatar
oh ok now i just need to find someone that sells the carpet and the matting as well i thinks hawks sells carpet have not seen the matting tho
Old Oct 27, 2011 | 01:04 PM
mantaguy's Avatar
Engine: 5.0 EFI
I got mine from 1A, and it comes with the insulation already attached.
Old Oct 27, 2011 | 01:11 PM
Warpedsv's Avatar
awesome thanks for the info I appreciate it.
Old Oct 27, 2011 | 01:38 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Found these guys for cut price Dynamat. I have used Hush and Fat Mat and don't think they can touch the Dynamat...
http://www.dealercostcaraudio.com/se...FRSfnAodh1zQJw
Old Oct 27, 2011 | 01:46 PM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
I did my entire Bronco in "Peel N Seal" from Lowes. Virtually the same as Dynamat at way below the price.
Old Oct 27, 2011 | 11:34 PM
inkedbass's Avatar
Peel N Seal is an asphalt based product designed for a roof. Under sun and heat it omits odors and chemicals that are toxic.
Check out Sound deadener showdown. They will show you the REAL proof not just some 'oh my audio guy swears by this product so its the product God would use if he drove a car'.
J
Old Oct 28, 2011 | 01:11 AM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
Hey another Bronco / Thirdgen owner
Im going peel n seal in the Bronco, if i keep it since its offroad only and fatmat, doubled up, in the vert. I want the best for the vert, but the differences between dynamat and fatmat in a CONVERTIBLE have to be negligible at best.
Old Oct 30, 2011 | 08:50 PM
Transmission: WC T5
Yeah, I never once smell any odors from my 91 Bronco and it stayed topless all summer, so at the peak temp of 115* it never once smelled. Mine was laid over Rustoleum liner btw.
Old Oct 30, 2011 | 10:13 PM
majobis's Avatar
Axle/Gears: G92
The kit I gave you the link to above (post 8) should include the roller and a small razor knife; both of which came in very handy.
Old Oct 31, 2011 | 03:39 PM
inkedbass's Avatar
Find a beater car or truck that has a top. Seal it up and set it in the sun for a few hours (imagine work hours) and then come back to it. You will notice an odor. I will guarantee it.
J
Old Oct 31, 2011 | 10:30 PM
Transmission: WC T5
It spent the summer before last with a top and PeelNSeal... Maybe I just got lucky?
Old Nov 1, 2011 | 02:07 AM
inkedbass's Avatar
Quite possible man.
I apologize if I was coming across as a know it all here. Car audio is one of my hobby's and a large part of it is sound deadner. It is quite possible your layers of carpet and other things over powered the smell.
J
Old Nov 1, 2011 | 07:09 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I've used fatmat on several projects, can't beat the price.
Old Nov 1, 2011 | 11:44 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I used FatMat, I could smell it in the beginning, but after about a week it disappeared.
Old Nov 1, 2011 | 02:41 PM
I would rather buy a good brand since this is going to be done once and will stay on forever pretty much. Some brands adhere to metal better than others and I know hushmat does not require a heatgun to get it to stick. When I read "best bang for your buck" I'm not sure what that means to be honest because that sounds like just getting some sound deadening but why not go the extra mile to put the best stuff in there and be done with it and make a noticeable difference in the comfort of the car?
Old Nov 1, 2011 | 03:53 PM
cdoyle's Avatar
J
I have peel and seal in my car, been in there for a couple years. Never really noticed any smells from it at all.
Car sat outside for a couple years too.
Old Nov 1, 2011 | 06:25 PM
Warpedsv's Avatar
I would prob go with the better quality since your only going to be doing this once and not every 2-3 years ya know
Old Nov 2, 2011 | 01:25 AM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
I didn't go cheap on the insulation, just wanted the best for my money. I was looking at Hushmat and Dynamat but ended up ordering Bonded logic heat and sound insulation from JC Whitney. I got a 4ft. x 48ft. roll for $179.99. Granted I have to use a spray adhesive to install it, the reviews said this is good stuff so we'll see. I'll take pics and give my thoughts once it gets here. And yes, once this is done I don't plan on tearing the new carpet out anytime soon. lol
Old Nov 2, 2011 | 07:29 AM
Warpedsv's Avatar
Awesome keep us updated with the progress
gixxer92
Apr 12, 2022 12:09 AM
InfernalVortex
Apr 20, 2021 11:31 AM
ULTM8Z
Oct 2, 2015 01:25 PM
dusterbd
Sep 29, 2015 08:40 AM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
