Crease in new Carpet....
Old Nov 12, 2011 | 09:17 PM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
Got my new carpet for my Iroc today, installation was going well untill I took a closer look at a crease running down the center between the rear seats.
this crease seems to be cast/formed into the mass backing.
Never ordered a carpet with mass backing before... Any chance that this will work itself out over time? I already sent an email to the supplier describing the problem as well....
Attached Thumbnails Crease in new Carpet....-2011-11-12_20-42
Old Nov 12, 2011 | 11:17 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Crease in new Carpet....
You have to let it sit out,stretched, in a warm room before you install it.Hopfully you didn't trim it yet.
Old Nov 12, 2011 | 11:30 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You can also smooth it out using a cloth iron in the steam mode. Be fare full about leaving it one spot too long
Old Nov 12, 2011 | 11:34 PM
Impaqt's Avatar
cut the holes for the center console.... sigh...
I can get my garage pretty warm, and I have a good heat gun as well(Backside only.. I'm sure it would melt the nylon). not sure how I would stretch it though..
Not too keen on the iron idea...
Old Nov 13, 2011 | 08:19 AM
mantaguy's Avatar
Engine: 5.0 EFI
I don't mean stretch literally,I mean lay out flat with a pull on each side.If you can pull it out I would do that.
Old Nov 13, 2011 | 08:31 AM
Impaqt's Avatar
I'll heat the garage up and bust out the heat gun today. kinda frustrating. knew I should of just done dynamat and the standard carpet
Old Nov 17, 2011 | 09:12 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
This came from the way it was packaged, not because of what type you got. Most installers let the carpet sit outside in the sun for a few hours to soften and take a new shape. The crease you are seeing was probably a fold in the shipping process.
Old Nov 17, 2011 | 09:43 AM
Impaqt's Avatar
Thats what I thought as well... Unfortunately, Chicago in November isnt exactly "Heat up the carpet" type of weather. I've kept the garage in the mid 70's the past week as much as possible and it hasn't relaxed at all.
Been talking to the company I ordered from and they are working on it. I tried heating it up with a heat gun, but because the crease in under an area withthe thick padding, I dont think I can get it hot enough without destroying that padding.
Formula99
Oct 8, 2006 06:59 AM
92F-bird_5spd
Nov 26, 2004 06:03 PM
CaysE
Jun 4, 2004 11:53 PM
