Am I missing an interior panel?
Old Nov 14, 2011 | 08:48 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Just about finished my interior, was putting the final pieces back together when I realized that I (might) be missing a piece. On the passenger side, there is a panel that goes up under the dash and conceals all of the wires (it has a little bulb that installs in it). But I don't have a similar panel for the driver's side. I looked through all of my old parts and I don't have anything, nor do I remember taking one off.
My question is...should there be some sort of panel there? Looks like it would go right behind or above the pedals.
Old Nov 14, 2011 | 09:06 AM
Steven6282's Avatar
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
Re: Am I missing an interior panel?
Yes there is a panel for the driver side as well. And it should have a removable fuse box door in it.
I know that a lot of people take them off and leave them off though. I haven't had mine on in a year because I'm under there working on stuff so often, running new wires for things and such. You don't really notice it unless you are squatting down outside the car with the door open... or you are shorter than 3 feet
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
Yes, there should be a panel there. Its big. Covers the entire underdash, covers fusebox to center console.
Old Nov 14, 2011 | 10:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Some cars were equipped with hush panels, others weren't. The link below may be interesting reading:
https://www.thirdgen.org/forums/hist...-plastics.html
JamesC
Old Nov 17, 2011 | 09:10 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
If you didn't take one off, then you aren't missing it today. It might have been removed long ago or it might have never been there. Do you have the courtesy lights under the dash. If so, the driver's side should be hanging by a wire if you had the panel. If the light is attached to a small bracket on the column, then you never had the hush panel on the driver side.
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
AkDrifted
Aug 17, 2015 07:45 PM
Exxon Limited
Aug 9, 2015 08:13 PM
