How Do I Remove Cigarette/Defrost Bezel?
Old Nov 16, 2011 | 04:16 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
I went to replace my defroster bezel with a better condition one that I bought and I unscrewed the bezel and it pulled out about 1/2 inch. Seems like there are wires back there and they arent giving me any slack to pull the bezel out far enough to remove everything.
Any ideas?
Old Nov 16, 2011 | 04:26 PM
Twin_Turbo's Avatar
Re: How Do I Remove Cigarette/Defrost Bezel?
The connector for the cigarette lighter is most likely hanging up on the plastic. If you can sneak in there with a small screwdriver you can get it off. It has a hook on both sides that clamp aroudn the back of the lighter housing.
Old Nov 30, 2011 | 08:51 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
So has that happened to you before? So Im imagining it has an L shaped plug going to the back of the element and is getting hung up inside the dash?
Old Nov 30, 2011 | 11:59 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
If you can't get to the plug in the rear then:
Unscrew the cig lighter!
Remove fuse then stick fingers in cig lighter hole and turn guts counter clockwise.
This (usually) will unscrew/seperate the cig lighter guts front portion from the power point and plug rear portion thats holding it in place.
Old Dec 1, 2011 | 07:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No L-shape. Note that I managed to manoeuvre the connector through the dash, making the disconnect much easier.
JamesC
Attached Thumbnails How Do I Remove Cigarette/Defrost Bezel?-img_0407.jpg   How Do I Remove Cigarette/Defrost Bezel?-img_0408.jpg   How Do I Remove Cigarette/Defrost Bezel?-img_0409.jpg
Old Dec 1, 2011 | 07:53 AM
JamesC's Avatar
To remove the lighter from the bezel itself, you do need to unscrew the parts. The lighter above wouldn't budge until I shot it with a bit of WD-40. After unscrewing, the silver piece simply pushes through the bezel.
JamesC
Attached Thumbnails How Do I Remove Cigarette/Defrost Bezel?-img_0414.jpg   How Do I Remove Cigarette/Defrost Bezel?-img_0415.jpg   How Do I Remove Cigarette/Defrost Bezel?-img_0416.jpg
Old Dec 1, 2011 | 08:54 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Wow thank you so much for the info.
And james thanks for the pictures! That will help a ton!
Old Dec 1, 2011 | 09:03 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Perfect. This thread will be useful in the next week or two when I (FINALLY) have a garage to work in again.
Old Dec 3, 2011 | 12:14 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
YUP!...............James also had the right idea and pics too!
Thats the EASY way Because the power wire locks/clips onto the lighter
and its a PIA to access it from the back !!!!!!!!!!!
Old Dec 3, 2011 | 12:36 AM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
I may need to do this eventually as well. This will be a good reference thread.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Randomtask2
Sep 10, 2015 08:37 AM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
