surface rust repair before carpet goes back in
Old Nov 18, 2011 | 11:02 AM
ls1 hunter's Avatar
Car: 91 RS
Engine: 421 18 degree sbc.
Transmission: 2 speed glide from tci
Axle/Gears: 9" ford 5.29 gears
I recently stripped my interior to change color of everything and I have small surface rust spots under carpet as I was wire brushing the floor. Should I paint over these spots or use something else to prevent worse rusting in the future?
Old Nov 18, 2011 | 03:40 PM
thirdgenmattw's Avatar
Car: '87 RS
Engine: LG4
Transmission: 4l60
Re: surface rust repair before carpet goes back in
Find a good chemichal rust stripper and use it after you've sanded down to bare metal, then primer&paint. That'd be the correct way to do it. If you don't completely remove all the rust, even the stuff you can't see, then it'll keep on eating at the metal and cause bubbles in your paint.
Old Nov 19, 2011 | 10:35 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Look at walmart for a rust stripper that costs 7.99 (i think),
it's like this one
http://www.walmart.com/ip/3M-Scotch-...of-10/15663697
Old Nov 22, 2011 | 01:41 PM
Adrenaline1's Avatar
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
I used a wire wheel, stripper, sealer, and then painted it. Just make sure you take care of both sides though while youre at it. Itll just start to rust through from the bottom if you just take care of what you see from the inside of the car.
Old Nov 22, 2011 | 01:43 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Give the interior a POR15 or rust bullet treatment.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
lee01
Apr 9, 2016 01:56 PM
LittleFranks
Aug 20, 2015 03:55 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
