Blower fan doesn't turn on
Old Dec 24, 2011 | 01:20 AM
algershick's Avatar
I just picked up my second third gen, an 86 Z28, for a steal, but it came with quite a few problems I've been chasing down. Drivers side window has been down the entire time the previous owner had it. I hooked up the window switch and replaced the door motor, problem solved. Ignition was busted and started with no key; I replaced the cylinder today, so that's fixed.
Now since I can seal the cabin with glass all the way around, I'm ready for some heat and a defroster! The fan switch doesn't do anything. I was just out fiddling with it tonight, I checked the plug with my multi-meter and got some really really low voltage readings from it. I'm not sure what it should read, though. Is there a way to troubleshoot the blower itself to see if its bad? Is there a relay I should check? All fuses are good.
Thanks!
Austin
Old Dec 24, 2011 | 03:40 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Blower fan doesn't turn on
the blower motor has a high speed relay, but if that goes out it just means you dont get HI, you still get the other 3 speeds. you can test the motor itself by applying 12v to it to make sure it spins.
Old Dec 24, 2011 | 04:12 PM
amlv20's Avatar
Car: 1986 iroc-z
Engine: 5.0 tpi
Axle/Gears: stock.
you should have 12v input to switch.
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
ZsTransAm
Aug 11, 2015 07:30 PM
